Full Version: Kodi.exe command line start VIDEO_TS movie!
I know that the following works:
Kodi.exe c:\temp\movie.mp4
(that will automatically start Kodi and the mp4 file will start playing)
I would like the same to happen, but with a ripped DVD folder like so:
Kodi.exe c:\temp\movie\VIDEO_TS
(Using the UI, Kodi plays these VIDEO_TS folders just fine!)
I would like the ability to launch this via command line! Thanks guys!
In case I was not clear, MPC can be launched at command prompt to play VIDEO_TS folders like so:
"C:\Program Files\MPC-HC\MPC-HC.1.7.13.x64\mpc-hc64.exe" "C:\Band\Block Party Video\VIDEO_TS" /DVD /fullscreen
So I was hoping for the same thing in Kodi.
Cheers!
You could try
Kodi.exe c:\temp\movie\VIDEO_TS\VIDEO_TS.IFO
As VIDEO_TS.IFO is the index file for initiating disc playback on DVD.
Thank you jjd-uk.
Unfortunately, no go.
Kodi just starts normally and displays the home screen.
