Full Version: Trakt query with this skin.
I have had to reinstall kodi with this skin as I had lost eveything but thats another story.
I use to use the Library function within Kodi so when I clicked on TV SHOWS from the main menu up would pop a list of all the shows I was following.I had it showing only the unwatched episodes.After the reinstall I am using Trakt.tv instead of Library.Is there a way in skin settings I can have the same system but using Trakt.I love the skin so am sticking with it and hope to get this sorted.
Transparency! is a skin I've come to rely on, from my point of view it should have been default, but it's a bit too much tweaking for your average newbie. I did use Trakt many years ago, but found it really didn't do much for my user experience and created more issues. You know that the keyboard 'w' toggles the watched status in both episode, folder and series, this function also works from the context menu as 'mark as unwatched'? Watched & unwatched as views are available in the left slideout. Is this the information you need?
I tried Trakt for a few hours but found it unreliable.
I have gone back to using the Library function.
I like that when I click on TV Shows on the Kodi home screen it brings up a list of my TV Series from the Library.
As I scroll down through them the fan art is displayed as well as a short episode synopsis.
I do the same with the Films section.
I have it set up so it just displayed the series with unwatched episodes remaining.
