Full Version: <focusedlayout> memory/UI rendering bug issue with doModal and history stack - Help!
I'm currently building a own light The Movie DB info script (similar to ExtendedInfo), but I'm facing a very strange and annoying UI issue.
Each dialog object is stored in a list/stack to generate a dialog history, which works well. But after 2-4 dialogs a container is getting weird and focusedlayout of that list is completely "invisible" for the first page. Hard to describe so I've made a video.
I'm out of ideas, because I simply don't know where the problem does came from. I hope that somebody can point me to the correct direction.
Timestamp where the issue appears: https://www.youtube.com/watch?v=g5pGtKIv...tu.be&t=29
Code of my dialog manager:
https://github.com/sualfred/script.embua...ain.py#L60
Debug log:
https://paste.kodi.tv/payofofofe.kodi
Totally strange. If I temporary increase the item and focusedlayout by 100 pixel in the width the issue is does not happen. And only for the container with images. What is this......
Ok, found the issue.
It's because close() doesn't deletes the window and each time it was reopened from stack it was passing onInit() again where I was adding items to the container controls. A simple self.first_load bool to check if it's the first time that this window is going to be loaded did the trick.
Thread marked solved.
