XanderKuhn
You are using nfo files, so the problem is not in the scraper. The problem is in your nfo files. I suggest you delete them or, if you prefer, upload the contents of the movie.nfo file to
Kodi Paste Site and I can take a look at it.
Which program did you use to create them? They are not Kodi nfo files.
xml:
10:09:08.575 T:2168 DEBUG: VideoInfoScanner: Found matching full NFO file: Z:\MultiMedia\Movies\14 Cameras (2018)\movie.nfo
10:09:08.578 T:2168 DEBUG: VideoInfoScanner: Adding new item to movies:Z:\MultiMedia\Movies\14 Cameras (2018)\14 Cameras (2018).mp4
(2019-08-04, 11:22)Karellen Wrote: [ -> ]@XanderKuhn
You are using nfo files, so the problem is not in the scraper. The problem is in your nfo files. I suggest you delete them or, if you prefer, upload the contents of the movie.nfo file to Kodi Paste Site and I can take a look at it.
xml:
I did not intend to use NFO files. How do I change that KODI ignores the NFO files and get its own information? I would prefer Kodi scrape the information. I am using Media Companion to rename the files in the required format that Kodi requires and did not include any other information from media companion (or at least not knowingly).
(2019-08-04, 16:48)XanderKuhn Wrote: [ -> ] I did not intend to use NFO files. How do I change that KODI ignores the NFO files and get its own information?
Delete them, or move them so Kodi cannot see them.
(2019-08-04, 18:35)Karellen Wrote: [ -> ] (2019-08-04, 16:48)XanderKuhn Wrote: [ -> ] I did not intend to use NFO files. How do I change that KODI ignores the NFO files and get its own information?
Thank you that worked if I use the The Movie Database scraper but when I use the Universal Movie Scraper it complains that it can not connect to the server or something. I have some movies that I would like to scrape with the Universaal Movie scraper so that they can be done by IMDB.
(2019-08-05, 09:13)XanderKuhn Wrote: [ -> ]when I use the Universal Movie Scraper it complains that it can not connect to the server or something
Can you provide another
Debug Log that captures that problem. I should be able to see what the problem is.
The previous log is of no use now as it was using nfo files.
(2019-08-05, 09:29)Karellen Wrote: [ -> ] (2019-08-05, 09:13)XanderKuhn Wrote: [ -> ]when I use the Universal Movie Scraper it complains that it can not connect to the server or something
Can you provide another Debug Log that captures that problem. I should be able to see what the problem is.
Thank you for all your assistance below is the new log.
https://paste.kodi.tv/ibifehujex.kodi
XanderKuhn
Interesting issue, and something I don't understand why it is happening. It seems like the scraper or IMDB are returning a broken link...
xml:
DEBUG: ADDON::CScraper::FindMovie: Searching for '5th Passenger' using Universal Movie Scraper scraper (path: 'C:\Users\Xander\AppData\Roaming\Kodi\addons\metadata.universal', content: 'movies', version: '5.3.1')
DEBUG: scraper: CreateSearchUrl returned <url>http://akas.imdb.com/find?q=5th%20Passenger&s=tt|accept-language=en-us</url>
DEBUG: CurlFile:arseAndCorrectUrl() adding custom header option 'accept-language: en-us'
DEBUG: CurlFile::Open(0xa9a8ef0) http://akas.imdb.com/find?q=5th%20Passenger&s=tt
INFO: XCURL:llLibCurlGlobal::easy_acquire - Created session to http://akas.imdb.com
ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
DEBUG: CCurlFile::Open - effective URL: <https://www.imdb.com/find?q=5th%20Passenger&s=tt>
WARNING: CScraperUrl::Get: Can't find precise charset for HTML "http://akas.imdb.com/find?q=5th%20Passenger&s=tt|accept-language=en-us", using "UTF-8" as fallback
ERROR: ADDON::CScraper::Run: Unable to parse web site
Let me rule out one other possibility first.
You have the show named
5th Passenger (2018). That is correct according to TheMovieDB...
https://www.themoviedb.org/movie/352548-...uage=en-US
But you are using IMDB who have the show as
5th Passenger (2017)...
https://www.imdb.com/title/tt3165632/?re...f_=nv_sr_1
Can you change the year and see if it makes a difference? Let me know the outcome.
(2019-08-06, 01:08)Karellen Wrote: [ -> ]@XanderKuhn
xml:
You have the show named 5th Passenger (2018). That is correct according to TheMovieDB... https://www.themoviedb.org/movie/352548-...uage=en-US
But you are using IMDB who have the show as 5th Passenger (2017)... https://www.imdb.com/title/tt3165632/?re...f_=nv_sr_1
I have changed the name as you suggested but it is still not working. Still getting the same error.
https://paste.kodi.tv/oqucamutid.kodi
