I just did a complete re-install of the latest Kodi version from the Google Play Store on my Nvidia Shield TV. I'm trying to set it all up again, but now I can't find the TV Tunes add-on in the standard repository. Am I missing something?
Any help would be appreciated, thank you!
(2019-08-07, 04:51)Karellen Wrote: [ -> ]No it does not exist in the Kodi repo. It is banned as it breaches copyright by allowing downloading of musical works.
The approved replacement is this one... https://forum.kodi.tv/showthread.php?tid=332890
Thank you, I'll check it out.
Daaaaaamn! I wish I wouldn't have re-installed Kodi. It was crashing on launch due to TheTVDB's new API, and after a couple of days I still hadn't found a fix and was getting impatient, so I wiped and started fresh. About two hours later I figured out a likely fix/workaround. Definitely regretting my decision to re-install.
