Full Version: XBMCCustomRegis and AutoHotKey script no longer working
Hi, for years I've been using an RC6 infrared remote with XBMC Custom Regis and the accompanying AHK script that Elite360Gamer bundles with their software to control Kodi.
It's always worked fine apart from the slightly annoying thing of needing to reinstall every time Windows 10 updates.
But I was recently forced to clean install Kodi and now I'm getting an issue when I hit my green 'windows' button, which should load Kodi. Instead it's coming up with an error which I've detailed below:
Error: Failed attempt to launch program or document:
Action: <C:\Porgram Files (x86)\Kodi\Kodi.exe>
Params: <>
Specifically: The system cannot fine the file specified.
It seems as if the script is unable to determine if I'm using 32 or 64-bit Kodi and is looking for the 32-bit version, which doesn't exist on my system. I'm not sure why this is only happening now, the only thing I think that's changed is the version of Leia that I'm using (the current stable build).
Anyone have any ideas if something needs to be changed in this script for it to work with the newest version of Kodi?
