Full Version: Confluence dissappear from the get more
Confluence wasn't on the list last night
This morning it showed up two times & had a plugin install error
Now it not in the list again
New install on a new android TV
Now its back on the list & just installed fine...
I also tried to pulled the data folder & just replace with a good install & wouldn't run Confluence. Now did it again after confluence showed on the get more with replacing the folder & worked perfectly.
Why, is this... It has happened in the pas where confluence wasn't on the get more list
(2019-08-07, 18:55)Dezurfer Wrote: [ -> ]I also tried to pulled the data folder & just replace with a good install & wouldn't run Confluence. Now did it again after confluence showed on the get more with replacing the folder & worked perfectly.
There is nothing in the CHANGELOG at all.
I suggest that you try to get a debug log using the instructions I these forums.
If you don't get help here, you could consider opening an issue in the GitHub repo for Confluence.
