2019-08-08, 02:33
In pre 3.x releases, the renamer video format token would return 4k for 4k videos. In 3.x, it returns 2160p. Is there a way to revert this behavior and have it return 4k instead?
(2019-08-08, 09:05)mlaggner Wrote: [ -> ]that has been changed upon a request to be uniform (https://gitlab.com/tinyMediaManager/tiny...issues/551). there is no way to switch that to the other way since we can either use 4k or 2160p. And our goal is to use a consistent styleI've been thinking of how to solve this myself...there is very little examples on using JMTE with the Renamer out there...but couldn't you achieve this with the following?
(2020-06-20, 08:08)EarthBoundX5 Wrote: [ -> ](2019-08-08, 09:05)mlaggner Wrote: [ -> ]that has been changed upon a request to be uniform (https://gitlab.com/tinyMediaManager/tiny...issues/551). there is no way to switch that to the other way since we can either use 4k or 2160p. And our goal is to use a consistent styleI've been thinking of how to solve this myself...there is very little examples on using JMTE with the Renamer out there...but couldn't you achieve this with the following?
${if videoFormat = "2160p"}4K${else}${end}
I've tried it myself, but it doesn't seem to work...however, if I use ! or put 4K after else, it'll show 4K...so I know the Renamer is understanding the if statement, just maybe the data types for comparison are the problem? I tried using videoFormat.toString, videoFormat.toString(), and toString(videoFormat) with no luck...
(2020-06-20, 09:42)tars Wrote: [ -> ]You have single handled solved hours of headache for me...I hope OP sees this for themselves too.(2020-06-20, 08:08)EarthBoundX5 Wrote: [ -> ](2019-08-08, 09:05)mlaggner Wrote: [ -> ]that has been changed upon a request to be uniform (https://gitlab.com/tinyMediaManager/tiny...issues/551). there is no way to switch that to the other way since we can either use 4k or 2160p. And our goal is to use a consistent styleI've been thinking of how to solve this myself...there is very little examples on using JMTE with the Renamer out there...but couldn't you achieve this with the following?
This should work:
${foreach movie.videoFiles video}${if video.videoFormat = "2160p"}4K${else}${video.videoFormat}${end}${end}
(2020-06-20, 20:29)EarthBoundX5 Wrote: [ -> ]Well...maybe actually solved one headache and introduced another...(2020-06-20, 09:42)tars Wrote: [ -> ]You have single handled solved hours of headache for me...I hope OP sees this for themselves too.(2020-06-20, 08:08)EarthBoundX5 Wrote: [ -> ]I've been thinking of how to solve this myself...there is very little examples on using JMTE with the Renamer out there...but couldn't you achieve this with the following?
This should work:
I had no idea that I'd have to do a loop of videoFiles to get videoFormat in a way I could compare...since videoFormat is variable on it's own, I assumed it was that easy...
Thanks much!!
(2020-06-20, 20:59)EarthBoundX5 Wrote: [ -> ](2020-06-20, 20:29)EarthBoundX5 Wrote: [ -> ]Well...maybe actually solved one headache and introduced another...(2020-06-20, 09:42)tars Wrote: [ -> ]This should work:You have single handled solved hours of headache for me...I hope OP sees this for themselves too.
Thanks much!!
I've confirmed it works, I can append it to the end of my current naming string...but as soon as I do anything with it, it stops working...like if I try to adjust for 2K or 8K instead...or if I put it in the middle of my naming...and then even if I just start over in the same session or even just use this alone, it doesn't work...it's like it triggers some failure in the application and stops handling anything, even after a restart of TMM...and then randomly, it'll work again...
Am I nuts?
What could be wrong with this?
${,movieSet.title,\}${title} ${- ,edition, }${foreach movie.videoFiles video}${if movie.videoFiles.videoFormat = "2160p"}- 4K ${else}${end}${end}${- ,3Dformat, }(${year})
${if movie.mainVideoFile.videoFormat = "2160p"}4k${else}${videoFormat}${end}
(2020-06-21, 07:48)mlaggner Wrote: [ -> ]you shouldn't do the loop in the rename because if your movies are splitted into more than 1 files, the token fill repeat. You could do the same thing with the undocumented fiel mainVideoFile
Code:${if movie.mainVideoFile.videoFormat = "2160p"}4k${else}${videoFormat}${end}
