This is from my log file, I get the channellist but freezes when try to play the channel:
21:42:56 T:652 M:169148416 DEBUG: Curl:: Debug HTTP/1.1 200 OK
21:42:56 T:652 M:169148416 DEBUG: Curl:: Debug Server: streamts (ts)
21:42:56 T:652 M:169148416 DEBUG: Curl:: Debug no chunk, no close, no size. Assume close to signal end
21:42:56 T:652 M:169148416 DEBUG: Curl:: Debug Expire cleared
21:42:56 T:652 M:169148416 DEBUG: Curl:: Debug Closing connection #0
21:42:56 T:2532 M:169148416 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info starting
21:43:06 T:2532 M:169062400 INFO: ffmpeg: [mpegts] Could not find codec parameters (Video: mpeg2video)
21:43:06 T:2532 M:169062400 INFO: ffmpeg: [mpegts] Could not find codec parameters (Audio: mp3)
21:43:06 T:2532 M:169058304 INFO: ffmpeg: [mpegts] Could not find codec parameters (Audio: mp3)
21:43:06 T:2532 M:169058304 WARNING: could not find codec parameters for
http://root:[email protected]:31339...29c,,,0202
21:43:06 T:2532 M:169304064 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
21:43:06 T:2532 M:169299968 NOTICE: CDVDPlayer::OnExit()
21:43:06 T:3408 M:169299968 ERROR: Playlist Player: skipping unplayable item: 0, path [tuxbox://root:
[email protected]/cgi-bin/zapTo?path=1:0:1:5e4:f:46:fff60000:0:0:0:.ts]
21:43:06 T:3408 M:169299968 DEBUG: Playlist Player: no more playable items... aborting playback
21:43:06 T:2532 M:169299968 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:43:06 T:3408 M:169295872 NOTICE: CDVDPlayer::CloseFile()
21:43:06 T:3408 M:169295872 NOTICE: DVDPlayer: waiting for threads to exit
21:43:46 T:652 M:168640512 DEBUG: Curl:: Debug Operation too slow. Less than 1 bytes/sec transfered the last 10 seconds
21:43:46 T:652 M:168640512 DEBUG: Curl:: Debug Expire cleared
21:43:46 T:652 M:168640512 DEBUG: Curl:: Debug Closing connection #0
21:43:46 T:652 M:168640512 INFO: CFileCache:
rocess - Hit eof.
21:43:46 T:652 M:168640512 DEBUG: CThread:
taticThread, deleting thread graphic context
21:43:46 T:652 M:168640512 DEBUG: Thread 652 terminating
21:43:46 T:2532 M:168665088 DEBUG: FileCurl::Close(0907E978)
21:43:46 T:2532 M:184422400 DEBUG: CThread:
21:43:46 T:2532 M:184422400 DEBUG: Thread 2532 terminating
21:43:46 T:3408 M:184459264 NOTICE: DVDPlayer: finished waiting
21:43:46 T:3408 M:184459264 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\avutil-49.dll)
21:43:46 T:3408 M:184459264 INFO: XCURL:
llLibCurlGlobal::CheckIdle - Closing session to http ://192.168.0.182 (easy=09594878, multi=0959CEF0)
21:43:46 T:3408 M:183013376 DEBUG: SDLKeyboard found something unknown (unicode <> printable ASCII): scancode: 29, sym: 306, unicode: 0, modifier: 0
21:43:46 T:3408 M:183013376 DEBUG: CApplication::OnKey: 61602 pressed, action is 0
21:43:46 T:164 M:183001088 DEBUG: CThread:
taticThread, deleting thread object
21:43:46 T:164 M:183001088 DEBUG: Thread 164 terminating
21:43:46 T:3408 M:183025664 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\avcodec-51.dll)
21:43:47 T:3408 M:183033856 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\avformat-52.dll)
21:43:47 T:3408 M:188379136 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\players\dvdplayer\swscale-0.5.0.dll)
21:43:48 T:3408 M:188715008 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib.dll)
21:43:52 T:3408 M:190533632 DEBUG: CApplication::OnKey: 61467 pressed, action is 10
21:43:52 T:3408 M:190513152 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
21:43:52 T:3408 M:190693376 DEBUG: CGUIWindowManager:
reviousWindow: Activate new
21:43:52 T:3408 M:190693376 INFO: Loading skin file: Home.xml
21:43:52 T:3408 M:190648320 DEBUG: Load Home.xml: 26.77ms (4.73 ms xml load)
21:43:52 T:3408 M:190156800 DEBUG: Alloc resources: 79.90ms (27.87 ms skin load, 0.27 ms preload)
21:43:55 T:3408 M:190496768 DEBUG: CApplication::OnMessage : Translating ActivateWindow(ShutdownMenu)
21:43:55 T:3408 M:190648320 DEBUG: CApplication::OnMessage : To ActivateWindow(ShutdownMenu)
21:43:55 T:3408 M:190648320 DEBUG: Activating window ID: 10111
21:43:55 T:3408 M:190648320 DEBUG: Checking if window ID 10111 is locked.
21:43:55 T:3408 M:190648320 INFO: Loading skin file: DialogButtonMenu.xml
21:43:55 T:3408 M:190611456 DEBUG: Load DialogButtonMenu.xml: 11.08ms (2.12 ms xml load)
21:43:55 T:3408 M:186826752 DEBUG: Alloc resources: 168.13ms (11.48 ms skin load, 0.37 ms preload)
21:43:58 T:3408 M:186834944 DEBUG: CApplication::OnMessage : Translating XBMC.ShutDown()
21:43:58 T:3408 M:186834944 DEBUG: CApplication::OnMessage : To XBMC.ShutDown()
21:43:58 T:3408 M:186830848 NOTICE: Storing total System Uptime
21:43:58 T:3408 M:186830848 NOTICE: Saving settings
21:43:58 T:3408 M:186785792 NOTICE: stop all
21:43:58 T:3408 M:186785792 DEBUG: CNetwork::NetworkMessage - Stopping network services
21:43:58 T:3408 M:186785792 NOTICE: ES: Stopping event server
21:43:58 T:1576 M:186785792 NOTICE: ES: UDP Event server stopped
21:43:58 T:1576 M:186785792 DEBUG: CThread:
21:43:58 T:1576 M:186785792 DEBUG: Thread 1576 terminating
21:43:58 T:3408 M:186814464 NOTICE: stop dvd detect media
21:43:58 T:3784 M:186814464 DEBUG: CThread:
21:43:58 T:3784 M:186814464 DEBUG: Thread 3784 terminating
21:43:58 T:3408 M:186843136 NOTICE: clean cached files!
21:43:58 T:3408 M:186839040 NOTICE: unload skin
21:43:59 T:3408 M:186839040 NOTICE: stop python
21:43:59 T:3408 M:186839040 NOTICE: stopped
21:43:59 T:3408 M:186839040 NOTICE: destroy
21:43:59 T:3408 M:189919232 NOTICE: unload sections
21:43:59 T:3408 M:189919232 DEBUG: SECTION:UnloadAll(DLL: Q:\system\libcurl.dll)
21:43:59 T:3408 M:189919232 DEBUG: NativeDllLoader: Unloading: libcurl.dll
21:43:59 T:3408 M:192028672 INFO: lastfm destroyed
21:43:59 T:3408 M:192057344 NOTICE: application stopped...
