Is there a way to use the YouTube add-on or an other add-on for
xml:
<content>plugin://..../youtubeusersearch&id=$INFO[ListItem.Label]</content>
I wouldt like to have YouTube results for selected artist in DialogMusicInfo
plugin://plugin.video.youtube/kodion/search/query/?q=$INFO[ListItem.Label]&search_type=videos
Note: "search_type=videos" is not a valid argument, but it supresses unwanted folder icons from the addon.
(2019-08-09, 16:04)sualfred Wrote: [ -> ]Code:
Thanks a lot, I'll try it later, when I'm home
you can get youtube to display search from a library node to a widget
xml:
<?xml version='1.0' encoding='UTF-8'?>
<node type="folder">
<label>row1</label>
<path>plugin://plugin.video.youtube/kodion/search/query/?q=today+i+found+out/</path>
</node>
so maybe you could add a widget row
