Full Version: Kodi crashes on Startup
Hi.
I got a Nvidia Shield and my Kodi still crashes at startup. It is set to start scarping using tvdb from startup Sad
The folders containing the addons are empty :o
My kodi log:
2019-08-09 16:10:40.289 T:20024  NOTICE: -----------------------------------------------------------------------
2019-08-09 16:10:40.289 T:20024  NOTICE: Starting Kodi (18.3 Git:20190619-89472b7d69). Platform: Android ARM 64-bit
2019-08-09 16:10:40.289 T:20024  NOTICE: Using Release Kodi x64 build
2019-08-09 16:10:40.289 T:20024  NOTICE: Kodi compiled 2019-06-28 by Clang 7.0.2 (https://android.googlesource.com/toolchain/clang 003100370607242ddd5815e4a043907ea9004281) (https://android.googlesource.com/toolchain/llvm 1d739ffb0366421d383e04ff80ec2ee591315116) for Android ARM 64-bit API level 21 (API level 21)
2019-08-09 16:10:40.290 T:20024  NOTICE: Running on NVIDIA SHIELD Android TV with Android 9.0.0 API level 28, kernel: Linux ARM 64-bit version 4.9.140-tegra-g8e6798163e77
2019-08-09 16:10:40.293 T:20024  NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-08-09 16:10:40.293 T:20024  NOTICE: Host CPU: ARMv8 Processor rev 1 (v8l), 4 cores available
2019-08-09 16:10:40.293 T:20024  NOTICE: Product: foster_e, Device: foster, Board: foster_e - Manufacturer: NVIDIA, Brand: NVIDIA, Model: SHIELD Android TV, Hardware: foster_e
2019-08-09 16:10:40.295 T:20024  NOTICE: External storage path = /storage/emulated/0; status = ok
2019-08-09 16:10:40.295 T:20024  NOTICE: ARM Features: Neon disabled
2019-08-09 16:10:40.295 T:20024  NOTICE: special://xbmc/ is mapped to: /mnt/expand/14a780e6-7b45-4a97-a9b0-d048dec4b347/user/0/org.xbmc.kodi/cache/apk/assets
2019-08-09 16:10:40.295 T:20024  NOTICE: special://xbmcbin/ is mapped to: /mnt/expand/14a780e6-7b45-4a97-a9b0-d048dec4b347/user/0/org.xbmc.kodi/cache/apk/assets
2019-08-09 16:10:40.295 T:20024  NOTICE: special://xbmcbinaddons/ is mapped to: /mnt/expand/14a780e6-7b45-4a97-a9b0-d048dec4b347/user/0/org.xbmc.kodi/cache/apk/assets/addons
2019-08-09 16:10:40.295 T:20024  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
2019-08-09 16:10:40.295 T:20024  NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
2019-08-09 16:10:40.295 T:20024  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
2019-08-09 16:10:40.295 T:20024  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
2019-08-09 16:10:40.295 T:20024  NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
2019-08-09 16:10:40.295 T:20024  NOTICE: The executable running is: /mnt/expand/14a780e6-7b45-4a97-a9b0-d048dec4b347/app/org.xbmc.kodi-MwPRID3v3BdkRAX8jAOpuA==/lib/arm64/libkodi.so
2019-08-09 16:10:40.295 T:20024  NOTICE: Local hostname: [unknown]
2019-08-09 16:10:40.295 T:20024  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
2019-08-09 16:10:40.299 T:20024  NOTICE: -----------------------------------------------------------------------
2019-08-09 16:10:40.313 T:20024    INFO: loading settings
2019-08-09 16:10:40.314 T:20024  NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-08-09 16:10:40.314 T:20024   ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
2019-08-09 16:10:40.314 T:20024 WARNING: Failed to save the default settings to special://masterprofile/guisettings.xml
2019-08-09 16:10:40.314 T:20024   FATAL: unable to load settings
Sorry but I tried to use paste.kodi.tv but couldn't find out how to use it :I(
What to do?
DB
Peter
@PPlys
I don't think that is a TVDB problem. Looks like you have a corrupt install. I will split your post and move it to Android forum and others may be able to help you fix the problem.
Hi
Did you get this fixed? I've got the exact same problem. It started after the tvdb issue and after trying all the fixes for that with nothing working I did a fresh install and my log file looks identical to yours.
nvidia shield with experience 8.0, kodi 18.3
Fixed by doing a full factory reset of the shield and starting again! Strange but there you go...
(2019-08-09, 16:43)PPlys Wrote: [ -> ]My kodi log:
Next time, kindly use a pastebin website for logs and other text snippets. Smile
Thread marked solved.
(2019-08-14, 21:09)fraggermcg Wrote: [ -> ]Fixed by doing a full factory reset of the shield and starting again! Strange but there you go...
This was the post I didn't want to read, or follow.
It was also the only advice that works. Thank you.
