Full Version: Non information provider movie library?
Hello!
I am using Kodi and while I have no problem importing movies using information providers such as The Movie Database to my library, I can't figure out how to import movies manually.
Let's say I have a home video or a fan made movie. Is there a way to import it into my library with all the other regular movies?
(2019-08-12, 01:49)Woody. Wrote: [ -> ]Let's say I have a home video or a fan made movie. Is there a way to import it into my library with all the other regular movies?
Yes. You can use a NFO File. See here... https://kodi.wiki/view/NFO_files/Movies
There is a sample file there. Just delete the sample data and replace it with your own. Instructions on how and where are on the page.
Thanks for answering.
But I have to admit that it seems pretty complex for me.
I will try to figure it out.
Let us know if you get stuck
Everything worked perfectly!
Thanks again.
Thread marked solved.
