Full Version: TV shows are not showing up
Pages: 1 2
Imagei read almost all threads. i searched name of the tv shows in tvdb and name it* but still all i can see just 1 tv shows
im using kodi 18.3 on my tv
Imagehttps://imgur.com/TIlumR6
Are you sure you're using the tvdb scraper and not themoviedb TV scraper which is now default?
(2019-08-12, 16:36)Hitcher Wrote: [ -> ]Are you sure you're using the tvdb scraper and not themoviedb TV scraper which is now default?
yes i i used imdb before but now tvdb
Check there's no NFO file messing things up and if it persists post a debug log while trying to scan that show.
(2019-08-12, 19:21)Hitcher Wrote: [ -> ]Check there's no NFO file messing things up and if it persists post a debug log while trying to scan that show.
there is no .nfo file.  just subtitles and videos.
https://ibb.co/pRMkC9b
(2019-08-12, 16:28)asdas Wrote: [ -> ]i read almost all threads.
Did you read this one... https://forum.kodi.tv/showthread.php?tid=336969
(2019-08-12, 22:44)Karellen Wrote: [ -> ]
not all of them but mostly. except .nfo file i believe i did everything alright. this is my log file
http://paste.kodi.tv/avaqucurew
Can't see The Office in that log but you have tv shows in your movies folder.
(2019-08-12, 23:23)Hitcher Wrote: [ -> ]Can't see The Office in that log but you have tv shows in your movies folder.
but how is that possible.i have separate orders for movies and tv shows as you can see in my first post. i changed scraper again to imdb maybe thats way?
@asdas
There is no IMDB scraper for TV Shows. To say that you were using IMDB for TV Shows indicates a problem with your setup.
Your log is no good. You did not enable Debug Mode in Settings>System Settings>Logging. Then restart Kodi and run an Update LIbrary.
Also provide a screenshot of your folder layout so we can see the parent folder and the Movies or TV Shows in that folder.
Also read Section 3 here... https://kodi.wiki/view/Naming_video_files#Source_Folder It would be worth reading the rest of the guide also.
(2019-08-13, 00:51)Karellen Wrote: [ -> ]@asdas
thank you so much for all answers Smile
​i just wanted to try imdb now im back to the tvdb. enabled debug mode restarted and updated library still same.
log: https://paste.kodi.tv/inavufevej
screens: https://imgur.com/a/ixKJquw
ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/
Seem your Kodi client has a problem reaching TheTVDB webserver.
Either you have a DNS problem, or the webserver is down.
(2019-08-13, 14:15)Klojum Wrote: [ -> ] ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/
is that cause name of the files maybe. i see Seinfeld without any problem
Going out on a limb here, but could it be the name of the folders containing S01 / S02 / other season numbers?
Going to causes a 404 error with the returned JSON being
json:
"Error": "Resource not found"
But going to returns the following JSON
json:
"data": [
"aliases": [
"Mitsubachi Maaya no Bōken",
"Shin Mitsubachi Maaya no Bōken",
"The New Adventures of Honeybee Maya"
"banner": "text/73518-2.jpg",
"firstAired": "1975-04-01",
"id": 73518,
"network": "ZDF",
"overview": "Bonsels' original book contains fewer than 200 pages. The storyline is centered on the relation of Maya and her many adventures.\r\n\r\nMaya is a bee born in a bee hive during internal unrest: the hive is dividing itself into two new colonies. Maya is raised by her teacher, Mrs. Cassandra. Despite Mrs. Cassandra's warnings, Maya wants to explore the wide world and commits the unforgivable crime of leaving the hive. During her adventures, Maya, now in exile, befriends other insects and braves dangers with them. In the climax of the book, Maya is taken prisoner by hornets, the bees' sworn enemies.\r\n\r\nPrisoner of the hornets, Maya learns of a hornet plan to attack her native hive. Maya is faced with the decision to either return to hive and suffer her due punishment, saving the hive, or leaving the plan unannounced, saving herself but destroying the hive. As may be expected, Maya, after severe pondering, makes the decision to return. In the hive, she announces the coming attack and is, totally unexpectedly, pardoned. The forewarned bees triumph over the hornet attack force. Maya, now a heroine of the hive, becomes a teacher, like Mrs. Cassandra and shares her experiences and wisdom with the future generation.",
"seriesName": "Maya the Bee",
"slug": "maya-the-bee",
"status": "Ended"
"aliases": [],
"banner": "graphical/266275-g5.jpg",
"firstAired": "2012-09-22",
"id": 266275,
"network": "ZDF",
"overview": null,
"seriesName": "Maya the Bee (2013)",
"slug": "maya-the-bee-2012",
"status": "Ended"
I dont think requesting a separate season will work. Requesting either a full show or a single episode should work.
Pages: 1 2
