Hi everyone!
I've recently install Kodi 18.3 Leia on my PC (Win 7). IPTV doesn't work... The sound is ok but there's no pictures.
I think I've tried everything
Settings> Player> Advanced
Under "Processing", I've tried " Auto Detect", "DXVA", "Pixels shaders", "Software".
I also tried with and without DXVA2.
Can anyone help me? Please help...
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Yes that is right except you did not replicate the problem (Step 3), so there is nothing to see. Whatever the problem, it needs to be captured while the log is running.
(2019-08-14, 19:47)Gman002 Wrote: [ -> ]Hi Karellen!
Karellen is currently snoozing on the other side of the planet.
Oops, he's still here
(2019-08-13, 22:31)Gman002 Wrote: [ -> ]I've recently install Kodi 18.3 Leia on my PC (Win 7).
2019-08-14 07:41:40.410 T:7772 NOTICE: Host CPU: Intel® Atom CPU N570 @ 1.66GHz, 4 cores available
2019-08-14 07:41:41.543 T:7772 DEBUG: selected Intel® Graphics Media Accelerator 3150 adapter.
I guess it's a wonder that your "PC" even runs at all, considering it's one of the slowest 8-9 year old machines. The graphics power should do 720p maximum, but all the processing/decoding has to be done by the CPU, and that is a lazy one. Is the Kodi GUI being displayed at all? Do 'normal' videos (not iptv) run on your Kodi setup?
I'd say that you would do yourself a favor when you get yourself something newer like a Raspberry Pi 3B+ (or 4B) and use LibreELEC. You will then have plenty of video graphics power for IPTV solutions. Not to mention no more noise pollution and a lower electricity bill.
LOL... I know my laptop is way too old
Yes, the Kodi GUI works, but I've got the same problem with "normal' Videos... (Sound OK, no pictures)
I Guess this laptop is way too old for Kodi....
Thanks for your help
