2016-12-05, 18:09
(2016-12-03, 16:05)Helly1206 Wrote: [ -> ](2016-11-28, 18:48)Intel1 Wrote: [ -> ]Hello, I have problems with the skin in the smart list rules section for videos.
When I want to add a new rule, I select a value and nothing appears in the field.
Skin: Xonfluence:
Skin Confluence:
Steps to reproduce:
1.Videos
2.Playlists
3.New smart playlist
4.Find item where - New rule
5.Click in arrow (Choose rule type)
Bug: There is no value chosen
I use kodi 17 beta 5 Xonfluence 3.3.10
Thank you.
I know there are some changes regarding playlists in krypton. I didn't implement them yet, because they were not available at that moment. But they seem to be now. Consider this issue solved in then ext release.
Thanks,
Helly.
Hi, thanks for replying, I updated to version: 3.3.12 and the problem is not solved, it is still the same, I can not see the values chosen when I add a new rule.
Thank you
