(2017-01-15, 10:29)Helly1206 Wrote: [ -> ] (2017-01-13, 22:18)enigmaa Wrote: [ -> ]In my Xonflunece skin, when browsing movies through files, i see 0B on the rating column for all movies. Same movies.. if i browse through genres tab, the rating shoes correctly.
Even if i change the Sort type and Veiw type, the 0B doesn't get removed. Appreciate help
I cannot reproduce. Can you make a screenshot?
Thanks,
Helly.
Find he screenshot requested
https://www.dropbox.com/s/ohprvaktwmpzo8...M.jpg?dl=0
Question:
Is their a way to add a m3u playlist as a playlist and not using PVR client? Then adding that playlist as a main menu item.
The PVR client is slow and causes my system to lag with larger playlists.
I've dropped a Sample.m3u into userdate/playlist.video and can play it from there without issue. I am wanting to add that as the main menu item on the menu bar....
being about to play individual channels by selection and not randomly as a playlist
Any ideas?
Hello.
I have noticed that wen I switch to Kodi 17 using the Xonfluence Skin, Kodi stays stuck "Migrating" and it never opens Kodi for the first time.
Has anyone else experienced this?
Hello,
Love the skin! Hands down best customization I've found!
I followed the super favorites widget issue and dont think my trouble was addressed there, I use custom widget favorites link for my trakt tv shows through ex----, works beautifully. For movies I use custom widget favorites link to people watching in ex---- also great, large home widget setting on thumbnail images work.
My problem is with custom widget from selected favorites thumbnail images. It comes when I use custom widget link to kodi favorite from super favorite. Thumbnail images dont show up in the widget. They show up when opened as super favorite and when I open the kodi favorite. I've manually added thumbnails to some super favorites and they still dont show up in the widget.
Similar trouble with custom widget thumbnails not showing up with kodi selected favorite links to 24/7 Shows in cCl--- addon and NES top 100 in Internet Archive Rom Collection Browser addon.
I'm running Kodi 17 RC (build kodi-20170115-5103bf7-Krypton-armeabi-v7a) , Xonfluence 3.3.15. and essentially having trouble with custom widget thumbnails that I didnt have with Kodi 16.1. Any suggestions?
Related screen shots: Can Send If Needed
Robdogbird
Can you please edit your post to remove the references to banned addons? We don't want this thread to be binned.
Banned Addons
Sorry about that, and thanks for the chance to adjust! Is the change OK?
Hi Helly,
I am using KRYPTON release of Xonfluence. I am unable to use the SELECTED FAVOURITES option in the widgets.
When i try to use this option , there is no OK button available to complete the action.[/size]
(2017-01-22, 13:17)gabriel1957 Wrote: [ -> ]Hi Helly,
Just hit back and it accepts your selection.
Hi Helly,
I am not too sure if Xonfluence Jarvis/Krypton supports animated weather icons and I was wondering if it's possible to add resource.images.weathericons.animated or Weather Plus to Xonfluence skin?
Could you tell me what I should do to make the animated weather icons compatible with this lovely skin please?
Any help would be appreciated.
Thanks mate.
I'm running the latest version, and for the life of me can't get random fanart to work.
I have TV Shows/Movies already in my library with fanart.
Does this work? and if so, can something guide me through the correct way to set it up?
Right, got a little further with this, seem to be getting some random fanart, (set to change every 10s, but sometimes no image appears for 30-40 seconds or longer, sometimes less)but with a lot of errors in the log.
Log link:
https://logs.tvaddons.ag/pu5xmswkd
check lines 663-865
Solved it. For anyone with similar issues, delete texture13.db in the database folder, and your thumbnails folder, and then let it rebuild them on kodi startup
(2017-01-24, 14:02)gabriel1957 Wrote: [ -> ] (2017-01-23, 02:41)Robdogbird Wrote: [ -> ] (2017-01-22, 13:17)gabriel1957 Wrote: [ -> ]Hi Helly,
Does not work?
Could you post a screen shot of the place you are having trouble? Where you want to hit ok but cannot? I think I had same issue, pic may confirm.
(2017-01-26, 10:13)beercajob Wrote: [ -> ] (2017-01-26, 01:17)Robdogbird Wrote: [ -> ] (2017-01-24, 14:02)gabriel1957 Wrote: [ -> ]Does not work?
http://s010.radikal.ru/i313/1701/47/0e13d82bd310.png
http://s019.radikal.ru/i638/1701/ba/0a630996971c.png
http://s019.radikal.ru/i635/1701/25/16cc92a9b497.png
After you double click IP music favorite does it return you to window where you selected custom widgets - favorite? If so, do not click cancel at that point, navigate back the same way you would if you had opened movies genre scifi. I use fire tv so not sure what keyboard equivalent is but you need to step back from window where you initially clicked custom widgets - favorites without clicking cancel. When you do, you should see the link address pop up. Let me know if you still have trouble
