(2021-04-30, 08:26)VonMagnum Wrote: [ -> ] (2021-04-29, 17:30)bsoriano Wrote: [ -> ] (2021-04-29, 16:38)VonMagnum Wrote: [ -> ]Yes, that works much better for me. The only oddity I noticed at first is if you have the ".." directory (go back directory) highlighted, it doesn't work at all (no Play Random) shows up. You actually have to have something in the list highlighted, which of course is never the case when you enter a directory or even TV Shows in general. It always highlights ".." by default so it's kind of a pain to have to move around in there before you can start something random.
@VonMagnum , my bad. Can you try now? I changed that behavior. I had not noticed since when I enter tv shows in my setup, the list is never positioned on "..".
Regards,
Bart
Yeah, it's working great now! Cheers!
Here's one crazy last idea, though. A couple of KODI versions ago, Team KODI thought it would be totally awesome to apply hardware acceleration on Android devices for ALL video types even fully knowing that it does NOT WORK properly with some video formats (.AVI and .WMV come to mind). Earlier versions automatically disabled hardware acceleration when such files were played, but they thought it would be a funny joke to purposely BREAK playback (so you have to go manually disable it for it to play smoothly) with some lame horse manure about consistent behavior NO MATTER WHAT it breaks. I can't say what I think about that decision without likely getting myself banned given the absurd logic used there and the PITA it is to keep turning hardware acceleration on/off all the time depending on what type of video file I want to watch on my FireTV 4K, but short of a breakaway KODI tree version just to put it back the way it should be until such time (likely never) that hardware acceleration is fixed for those formats, I'm wondering if a simple script option might work to automatically disable the options in KODI when playing those formats with a click option in the GUI settings for Xonfluence. I don't know if that's even possible to control from a skin option or script, but I have a nagging suspicion it could be and given how lightning fast you've fixed up this skin to work with Matrix, I'm thinking if anyone could do it, it's you.
Of course, if it's not possible or too much bother, that's fine too. You've already done far more than any of us could have hoped for getting one of the better skins ever made for KODI working again in Matrix. Frankly, you're the first person that has ever implemented a single request for something KODI related (Team KODI seems to literally hate requests by anyone so I've learned not to bother asking. I can't even get bugs fixed even when I do all they ask to provide log files in paste bin and test various things out. The Mac version of Matrix still crashes here EVERY TIME within a few minutes, for example even doing a clean install here (V18 worked fine). The most I got in return was asking whether I tried disabling thumbnail generation (I did try that) and then nothing. It's a waste of my time and theirs, apparently.) So, you're like a super hero by comparison. Great job!
VonMagnum, thanks for confirming that it is working, and for your kind words.
As for the Kodi setting, yes, I know of a script that can set/reset settings, so in theory it is possible. Could you please post a screenshot of what setting it is? Also, how do you envision this? A button in the OSD? Maybe a prompt when a file starts to play? If the latter, what are the file extensions that would need to have the setting turned off when you start playing them in Android? Again, I am not 100% sure it is doable, but I am willing to give it a go.
Regards,
Bart
EDIT: @
VonMagnum , to ensure that I get the correct setting, could you please in your Android system turn hw acceleration off in Kodi, and then PM a link to your "guisettings.xml" file? You can upload it to whatever cloud storage you use and PM me the link. I checked the script I was thinking of, and it can change the value for almost all Kodi settings. So, I was thinking of the following:
1. Add an option in Xonfluence settings to enable asking to disable hardware acceleration at the start of playback for xxx, yyyy, zzz type files (the option would only show up in an Android system, and you tell me which types of files are xxx, yyy, zzz and whatever others).
2. If the option in 1. is enabled, then, at the start of playback of one of the types of files you tell me, Xonfluence would pause the video, and show you a dialog asking if you want to turn off hardware acceleration for this video, if it is not turned off already. If you answer Yes, then via script.embuary.helper, Xonfluence would turn off the Kodi harware acceleration setting, and continue playing the video.
In order for this to work, I need to see your "guisettings.xml" file with the setting turned off (I do not have an Android system I can test with); if the setting is in that file, then embuary helper can set/reset/change its value.
