Full Version: Xonfluence (Leia v18.x & Matrix v19.x) (Krypton 17 = deprecated)
have found a little bug
LiveTV OSD shows channel numbers like in screenshot with (,) before the number
confluence has the numbers in the brackets
would it be possible to show it without the brackets?
number space channelname
Hey Helly,
Thanks for bringing the OSD buttons, while playing a DVD of ifo file, back on screen. Could you just shift them a little bit to the left so they all appear?
Thanks, Gerard
I apologize in advance if this is not the place to post this, but how do i get this installed on the krypton builds? the latest nightly just gives a "failed to install" error.
I like to put the latest version on my machine. So, I would like to see if anyone has been able to put it on the latest build.
If I add the repo, the skin doesn't show up at all, and I am assuming because it is I am using version 17..
(2016-02-18, 01:06)cabrio Wrote: [ -> ]I apologize in advance if this is not the place to post this, but how do i get this installed on the krypton builds? the latest nightly just gives a "failed to install" error.
Look back a few pages and you'll find Uukrul has made a version for krypton. You'll have to install by zip.
hi and thanks for updating the skin... its great, just one thing, every start up i get , i get an addon script error,
any ideas?
regards
it actually says addon error, and all the skin changes revert back to default,
edit... i think its ok now.. restarted my unit and thats seem to have fixed my issue... sorry about that
ta
(2016-02-17, 13:12)derders Wrote: [ -> ]have found a little bug
Ok, will fix it in the next release.
Helly,
(2016-02-17, 19:56)Only4me Wrote: [ -> ]Hey Helly,
Thanks, Gerard
Thought I'd fixed that. Maybe one button configuration I didn't test. Anyhow, I will check for the next release.
Thanks,
Helly.
(2016-02-18, 08:14)Helly1206 Wrote: [ -> ]Ok, will fix it in the next release.
Helly,
thank you
found something weird
In Fullscreen OSD cuts sometimes channelname and starttime but windowed not (have a look at screenshot please)
Hi I think I found the bug. On home screen with video played in background it is not possibse to highlight video controls if search button is set to be on the botton of the screen in skin settings. Please see screenshot. And thanks for great skin.
(2016-02-19, 15:14)derders Wrote: [ -> ]
Helly,
thank you
I need to update the fonts. Consider it fixed in the next release.
Helly.
(2016-02-19, 15:34)nhsman Wrote: [ -> ]Hi I think I found the bug. On home screen with video played in background it is not possibse to highlight video controls if search button is set to be on the botton of the screen in skin settings. Please see screenshot. And thanks for great skin.
Ok, I'll fix it in the next release.
Helly.
Hi all,
Another release with mostly bugfixes (thanks to you all for finding them).
Enjoy.
Helly.
3.2.5
- Fixed home stats bug when drive is unavailable #589
- Updated fonts to fix cut off of text #614
- Fixed Channel name and number not showing correctly when playing Live TV #601
- Fixed non working now playing buttons when search button is at bottom position #615
- Fixed OSD button position when playing DVD #602
- Added nodes option in skinsettings - submenu for music, movies, tvshows and concerts
Hi Helly, thank you so much for this great skin, really love it. please can you tell me if there is a way to make home floor alone transparent as current settings also affect the home menu. also there is no arrow pointer in the Home menu subset if the item is more than 6 which suppose to let someone know that there are still more hidden.
Thanks again bro for your hard work.
