(2016-02-24, 05:46)OTinley Wrote: [ -> ] (2016-02-24, 05:03)Rightstream Wrote: [ -> ]Hi helly thank you for all of your work it is appreciated and your code is solid. I am having problems with not being able to connect to repos is there a place in the xml I can change that. I am not able to see the addons in each repo or add them from the individual repos? Any helo would be appreciated
I doubt this has anything to do with the skin itself at all.
Please revert to default skin and try again.
Post a log as well.
thanks again for all of your help for me and all the other question askers im sure it gets a bit annoying.
I uninstalled my build as well as kodi and reinstalled still working with the confluence standard skin it is still throwing errors all over the place and wont allow me to access repos sql errors?
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon resource.uisounds.confluence
16:21:19 T:9684 ERROR: SQL: [Addons20.db] The database disk image is malformed
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='metadata.common.themoviedb.org'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon metadata.common.themoviedb.org
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='metadata.artists.universal'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon metadata.artists.universal
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='metadata.common.theaudiodb.com'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon metadata.common.theaudiodb.com
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='metadata.common.imdb.com'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon metadata.common.imdb.com
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='screensaver.greynetic'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon screensaver.greynetic
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='plugin.program.logviewer'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon plugin.program.logviewer
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='visualization.waveform'
16:21:19 T:9684 ERROR: CAddonDatabase::GetAvailableVersions failed on addon visualization.waveform
16:21:36 T:5060 WARNING: Attempt to use invalid handle -1
? any ideas?
