Full Version: Xonfluence (Leia v18.x & Matrix v19.x) (Krypton 17 = deprecated)
Regarding libraries, manually edit the addon_data settings.xml for the Addon in question.
I have all my movie and TV addons use the library folder on userdata. The path is special://home/userdata/library
Sent from my iPhone
Regarding icons, you can make a new folder in the addon_data folder called icons. Then put the images in there and point it to special://home/userdata/addon_data/icons/xxxxx.png that will work.
You can find the icons by looking through your thumbnails folder.
Sent from my iPhone
Thanks, really helpful. I will try both these suggestions tonight. Smile
(2016-05-18, 17:00)ed_davidson Wrote: [ -> ]Regarding libraries, manually edit the addon_data settings.xml for the Addon in question.
Sent from my iPhone
(2016-05-18, 17:03)ed_davidson Wrote: [ -> ]Regarding icons, you can make a new folder in the addon_data folder called icons. Then put the images in there and point it to special://home/userdata/addon_data/icons/xxxxx.png that will work.
Sent from my iPhone
FYI folder names are case sensitive.
Sent from my iPhone
The disappearing addon icons was how I found this issue in the first place.
I have a folder at Kodi root that I keep some icons and things in for my skin setup, and since this can be referred to as a special path folder too you can set it in the skin settings in the same way and it will work across all your devices. My folder is called "# art icons" but you can name it how you want.
So you need to go through and edit the skin settings for these addon icons too after you have made them, and point it to this new folder that you will make.
An example path would be special://home/# art icons\MyAddon TV Shows.png
(you need to edit your previous post to remove reference to this banned addon)
Change anything after special://home/ to match your particular folder and icon names.
Regarding your universal libraries, they can point to a special path too, as long as it's inside the Kodi root folder somewhere.
Or, if none of your devices will be taken outside the home, point to a network folder if your addon supports that and have one centralised folder for all your devices.
Normally an example path for what you are referring to would be: special://userdata/addon_data/plugin.video.myaddon/TV Shows
But per my above example you could also make your own folder and point it there, eg: special://home/TV Shows
I guess this is what you have done already, but you are pointing to it with a local path, instead of a special path. So just correct that in your addon settings.
Hope this helps Smile
Ah, I see my reply ended up being a little late. Thanks ed_davidson Smile
Yes, thanks both of you, ed-davidson's advice worked beautifully and my build is now completely universal!
(2016-05-18, 22:30)beergut100 Wrote: [ -> ]Yes, thanks both of you, ed-davidson's advice worked beautifully and my build is now completely universal!
Can you share your build?
Is nice to have a build with xonfluence.
(2016-05-20, 13:39)oxus Wrote: [ -> ]
No, I don't think sharing it here would be approved of.
Hello
I installed the hellyrepo,and try to donwload the new skin for kodi 16.0,but i just could't find the skin building in "look and feel" section,
did the skin stop updating?
Thanks for helping.
I am seeing it in the repo using 16.x but you can get it from github if you want:
https://github.com/Helly1206/skin.xonfluence
(2016-05-21, 03:15)OTinley Wrote: [ -> ]I am seeing it in the repo using 16.x but you can get it from github if you want:
Thank you for kind helping,i really appreciate that.
deleted
Bug latest version of skin 16.1 Jarvis/ Android (Fire Stick)
When adding a Favourite that is an Android App as Submenu item or Shortcut it fails to launch, I have to use the Kodi command to get android apps to launch via Submenu or Shortcut
Hello and thank you for the most amazing skin for kodi,
can I add an icon next to the category in the home menu?
if So you can give me the code?
ty very much
