Full Version: Xonfluence (Leia v18.x & Matrix v19.x) (Krypton 17 = deprecated)
(2016-10-14, 21:11)Helly1206 Wrote: [ -> ]
(2016-10-14, 14:51)SirLoinOfBeef Wrote: [ -> ]
(2016-10-10, 10:48)beercajob Wrote: [ -> ]dependency on xbmc.addon version 16.9.701 could not be satisfied
I too am getting this error when trying to install.
Any suggestions anyone?
Quite strange, Xonfluence doesn't have a dependency on xbmc.addon. I haven't ever seen this error.
Which version of XBMC and Xonfluence are you using?
Helly.
kodi 16.1 Jarvis http://s019.radikal.ru/i640/1610/fc/2c31bb072f03.png
Helly.
I am using Kodi 16.1 and trying to install Xonfluence from the repo.
Sent from my SM-G900I
(2016-10-15, 10:19)SirLoinOfBeef Wrote: [ -> ]
(2016-10-14, 14:51)SirLoinOfBeef Wrote: [ -> ]I too am getting this error when trying to install.
Helly.
Sent from my SM-G900I (typie typie)
I found the cause of your error. You have the wrong version of service.library.data.provider installed. Probably you have version 0.1.6 installed. That version is for Krypton. Jarvis uses 0.1.5.
Did you accidentally install xonfluence 3.3.x for Krypton? Maybe that one caused installation of v 0.1.6 of this service. Or something else went wrong.
You can install the correct version from github:
https://github.com/BigNoid/service.libra...tree/helix
Select Clone or Download, download zip and install from zip in kodi.
or install directly to kodi, see:
Add-on:Library_Data_Provider (wiki)
Success.
Helly.
Hello Helly1206, long time fan of your skin, lately I noticed that I can not save any changes that I make, maybe this was discussed before but I could not find the discussion so please forgive me. Is there something going on with the skin preventing me from doing so? HuhHuh
Hi Just trying your skin.
Is there anyway of saving any changes I have made and save it as the skin reset deaults?
By the way, Great Skin !!
Pejay
To save any customizations in Xonfluence, you needs to reload the skin. I usually make my changes, then do a proper exit from Kodi. I restart Kodi and all of my changes have been properly saved. I also think you can go to System > Skin Settings > Skin Reset > Save Settings and Reload Xonfluence.
(2016-10-15, 18:04)Helly1206 Wrote: [ -> ]Success.
Helly.
Thank you! I shall try this as soon as I get home
Thanks for that. I've managed to do that. What I want to know is where the default reset settings are so I can save it elsewhere. I presume it will be an
xml file?
I've taken a pointer from watching and listening... and found that going through the folders and saving the special xml scripts is the key for me...
Glass<^>Rain
By the way... Thanks for tips the other day on customized widgets... It helped well...
Glass<^>Rain
(2016-10-15, 23:40)UraFarquad Wrote: [ -> ]To save any customizations in Xonfluence, you needs to reload the skin. I usually make my changes, then do a proper exit from Kodi. I restart Kodi and all of my changes have been properly saved. I also think you can go to System > Skin Settings > Skin Reset > Save Settings and Reload Xonfluence.
@UraFarquad, Thank you
That saying "Can't see the forest for the trees" hahahaha thank you, never noticed the reload button just the reset one.
Worked great, thank you again.
(2016-10-16, 17:47)jbond7 Wrote: [ -> ]
You're welcome. Just trying to contribute in one way or another. lol
I want my movies to show a 3D tag on the screen. I have use .3d. in the filename to tag it but it does not show up. I have use .bluray. and the bluray tag shows but never 3d.Any ideas.?
(2016-10-18, 00:19)kbundy Wrote: [ -> ]I want my movies to show a 3D tag on the screen. I have use .3d. in the filename to tag it but it does not show up. I have use .bluray. and the bluray tag shows but never 3d.Any ideas.?
I have several 3D movies in my personal library that exist right next to the 2D counterparts of the same films (ex: Friday the 13th III in 3D). I usually edit the name to distinguish which version is which, but I would also like to see an icon displayed along with the other metadata icons.
I've also created a custom playlist to group all my 3D content to one list and have a custom button on the Home screen to access it.
Привет. Как сделать,чтобы при наведение на тв канал внизу отображалась EPG http://s018.radikal.ru/i502/1610/a2/64e31a78fbae.png
