Hi
Can someone tell me what media flags are on show for TV Shows (in order) and what do I need to do to make sure all are displayed.
Do Movies have different flags if so what are they.
Thank you
I have found out some :-
Studio - Age Rating - ? - Video Codec - Resolution - Bit - SD/HD - Aspect Ratio - Audio Codec -Sound Channels
Is this right
Anyone know what goes in place of the ? , none of my films have anything here.
(2019-08-20, 19:35)aceuk Wrote: [ -> ]I have found out some :-
Is this right
Mine shows Studio - MPAA Rating - Media Type - Video Codec - SDR/HDR - Bit - HD 1080p - Aspect Ratio - Audio Codec - Sound Channels
(2019-08-20, 20:24)SteveSmith Wrote: [ -> ] (2019-08-20, 19:35)aceuk Wrote: [ -> ]I have found out some :-
Is this right
So next to MPAA Rating you have Media Type (not ...)
Can you give me a example what is shown for media type
(2019-08-20, 21:34)SteveSmith Wrote: [ -> ]
Hi can I ask have you customised what is shown also how did you get those coloured flags I've been looking for some like this
(2019-08-20, 22:58)aceuk Wrote: [ -> ] (2019-08-20, 22:52)SteveSmith Wrote: [ -> ]Nothing was customized, its pulling the information from the file.
you can download the colored icons from this thread
MQ8 Original Topic
Buzniak also did an update to the icons here
Do you add info to the file name or use a program to add info to the file.
Thanks for link
Yes its in the filename, so as an example I have
Showname.S0X.E0X.720p.HDTV.x264.mkv
(2019-08-20, 23:03)SteveSmith Wrote: [ -> ] (2019-08-20, 22:58)aceuk Wrote: [ -> ] (2019-08-20, 22:52)SteveSmith Wrote: [ -> ]Nothing was customized, its pulling the information from the file.
MQ8 Original Topic
Thanks for link
So do I have to install the Multi Mod to get the colour flags.
I got the resolution & Vid codec but still missing some that are on show in your pic
No, you can install the zip files in the vanilla version..
I fixed the link so it will take you there now..
(2019-08-20, 23:10)SteveSmith Wrote: [ -> ]No, you can install the zip files in the vanilla version..
I tried both links and both go to same post and the links are what I have already DL
am I missing something
Yeah I messed up the link..
Melons 2 post
here
Please note the yellow box
I'm not getting the colour channels flag - any ideas why
Also how do I get rid of the eng which I think may be why I'm not getting the colour flag
