Hy,i try to explain what's my problem. I use nvidia shield with Kodi leila updated, i try to do two things. First create a new voice like "Video" or "Tv Show" called Cartoons, but if i edit a menù a don't see anythin on my home folder, so what can i do? The second is,follow this settings->elements->Video->and browse my folder on my Nas synology. I have 2 folder called Film and Film_2 with 340 films, more or less. I select Film filder, selected the type of content, selected the scraper and waited. I repeat the same process for Film_2, but when i go on Film on my home i see just 240 films. I tried also to create in settings->files a folder with inside my two folders, but not work. What can i do?
1) Adding a menu item 'Cartoons' should be possible, but you may need some skinning help for that.
2) You have two film root sources, 'film' and 'film_2'. The first one goes fine, as far as I can read. The second one, not so much. Problems with movies not being 'scraped' into the Kodi video library is often because of problems with file names.
Can you provide Kodi's
debug log (wiki), so we can perhaps see where the problems start?
(2019-08-21, 14:50)Klojum Wrote: [ -> ]1) Adding a menu item 'Cartoons' should be possible, but you may need some skinning help for that.
Can you provide Kodi's debug log (wiki), so we can perhaps see where the problems start?
First of all, thank for your reply!
1) Can you help me? Tutorial, guide, o whatever you want.
2) Here is
My Log. I see ther's some errors, can i fix it for example changing the name "film title is this" in "film_title_is_this" ?
Thank you so much
Apparently there are a couple of stack problems
2019-08-21 15:09:07.633 T:858 WARNING: CreateLoader - unsupported protocol(stack) in stack://smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_1.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_2.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_3.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_4.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_5.mkv
2019-08-21 15:09:07.835 T:858 WARNING: No information found for item 'stack://smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_1.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_2.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_3.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_4.mkv , smb://192.168.1.44/Film/Ale e franz - Buona la Prima/BUONA_LA_PRIMA_DVD_5.mkv', it won't be added to the library.
2019-08-21 15:09:07.856 T:858 WARNING: CreateLoader - unsupported protocol(stack) in stack://smb://192.168.1.44/Film/Colpo di fulmine/[DivX ITA] Colpo di fulmine CD1.avi , smb://192.168.1.44/Film/Colpo di fulmine/[DivX ITA] Colpo di fulmine CD2.avi
2019-08-21 15:09:07.895 T:858 WARNING: No information found for item 'stack://smb://192.168.1.44/Film/Colpo
[DivX ITA] Colpo di fulmine CD1.avi Starting a filename with such a prefix will not get it 'scraped' in the the Kodi database easily.
Have a look here for instructions on stacking video files:
https://kodi.wiki/view/Naming_video_file...ovie_Files
(2019-08-21, 15:55)Klojum Wrote: [ -> ]Apparently there are a couple of stack problems
Have a look here for instructions on stacking video files: https://kodi.wiki/view/Naming_video_file...ovie_Files
Ok so, i'll try, but there's so many files (films) that kodi don't recognize. I understand that 3 files are "in trouble" but ther's many other dont'. More or less 100.
Perhaps the menù called "cartoons" how can i create?
(2019-08-21, 16:16)Paperino78 Wrote: [ -> ] (2019-08-21, 15:55)Klojum Wrote: [ -> ]Apparently there are a couple of stack problems
Hy guys, finally seems to be solved the first problem. Now after i renamed 100 film, kodi find them all, finally kodi view all my films. Thanks For the second problem, i find a estuary mod for my kodi 18.3 and i'm tring to create a new voice in home menù, but i dont understand what have to do after that. Ther's no other voices when select my new item, no widgets, no recents, no actors, no for all voices that are present in Film item. Anyone can tell me how can i do?
Everything went well. I created my new item and separated films and cartoons and other things. There are still some things to do, but for now it's ok. So anyone can tell me if there's a way to edit the language for this skin?
(2019-08-26, 01:03)Karellen Wrote: [ -> ] (2019-08-22, 23:21)Paperino78 Wrote: [ -> ]So anyone can tell me if there's a way to edit the language for this skin?
Yes. Change settings as shown here... https://kodi.wiki/view/Settings/Interface/Regional
Thanks, but it's the first thing I have done when I installed kodi. I mean that estuary mod v2 was not really translate completely in Italian, so it's a long and hard work to do. Maybe I'll try to do something like translate some piece of code o something like this.
(2019-08-26, 10:43)Paperino78 Wrote: [ -> ]I mean that estuary mod v2 was not really translate completely in Italian, so it's a long and hard work to do.
Ok. Kodi uses transifix for language. Maybe you could contribute there?
https://www.transifex.com/teamxbmc/kodi-main/
Otherwise check your add-on folder for
resource.language.it_it and edit the
strings.po file using a text editor.
If using Windows, it is here...
C:\Users\<username>\AppData\Roaming\Kodi\addons\resource.language.it_it\
(2019-08-26, 11:02)Karellen Wrote: [ -> ] (2019-08-26, 10:43)Paperino78 Wrote: [ -> ]I mean that estuary mod v2 was not really translate completely in Italian, so it's a long and hard work to do.
Ok. Kodi uses transifix for language. Maybe you could contribute there? https://www.transifex.com/teamxbmc/kodi-main/
Otherwise check your add-on folder for resource.language.it_it and edit the strings.po file using a text editor.
If using Windows, it is here... C:\Users\<username>\AppData\Roaming\Kodi\addons\resource.language.it_it\
Thank you so much. I'll try on my pc, and if I'll have a little bit of time I'll do the same thing on transifex.
(2019-08-26, 11:06)Paperino78 Wrote: [ -> ] (2019-08-26, 11:02)Karellen Wrote: [ -> ] (2019-08-26, 10:43)Paperino78 Wrote: [ -> ]I mean that estuary mod v2 was not really translate completely in Italian, so it's a long and hard work to do.
Hi, sorry for the late, but where could i find the language file in estuary mod v2 skin? Kodi was translated well, but estuary not at all. Maybe i could try in local on my nvidia shield.
I don't have the mod v2 skin installed, but it should the in the language folder of the skin in the add-ons folder.
Find the skin folder and you will find the languages.
