2019-08-23, 02:50
2019-08-23, 02:50
2019-08-23, 19:23
here is a video example of what I'm talking about because I didn't find this option in kodi and would like to know if you have.
aqui esta um exemplo em vídeo do que estou falando pois não achei essa opção no kodi e gostaria de saber se tem.
youtube:
youtube:
2019-08-24, 17:56
2019-08-24, 23:21
According to that post (and the Wiki for Keyboard shortcuts) it's a simple matter or Alt+Left or Alt+Right to speed up or slow down. The wiki mentions these limitations though:
- Speed range limited to 0.8x - 1.5x speed
- Only works when Sync Playback to Display is enabled which will Disable Audio Passthrough
2019-08-27, 01:41
Removed
2019-09-04, 19:46
