Full Version: Can't Navigate to Backgound Photo
Hi All,
I've recently upgraded my Firestick to the 4K version. All without any problem. I have 3 attached NAS's and have created video sources related to each. I'm using the same Confluence skin that I 've used in 2 previous setups. It all works beautifully. The last thing I wanted to do - what I thought would be the easiest of all was to change the Background jpeg, and so....
I went into system settings / interface / configure skin / background / enabled custom background / clicked on "Background Path"
On the resulting page (entitled Browse for image) I'm presented with 2 options...
External Storage
Root Filesystem
So far so good, however, when I click on "External Storage" instead of seeing my NAS's I get a list of 10+ folders entitled....
Alarms
Android
backups
DCIM
etc etc
If I click on root filesystem the cursor just bounces up to External storage. How the heck do I navigate to my required image Huh (which is located on one of my NAS drives)
I can easily navigate to the required image in file manager and display it - no problem - so why the heck can't I navigate to it in "Skin Settings - Background" ??
The questions I need answers to are....
1. Why aren't my drives, which are easily found, and used, in another part of KODI (Add Videos) NOT visible when I click on "External Storage"
2. Why can't I enter "Root filesystem"
HELP !!!
Add your NAS to the file manager so it appears when you open that menu.
(2019-08-24, 22:38)Hitcher Wrote: [ -> ]Add your NAS to the file manager so it appears when you open that menu.
Thanks for your reply. Could you give me more detail please - I'm able to add the network folder location (where my jpeg is) to file manager - but not an actual drive letter - it's not in the list for addition. But as I said earlier, I can easily navigate to my required jpeg in file manager.
IF I was allowed to select "Root Filemanager" to set the path for background Jpeg this thread would not exist! I'm truly baffled as to why I cant select root in this instance. Thinking out loud - Is it a KODI permission thing? - no it can't be because I can easily access file manager...
I love it when a plan comes together ! - But unfortunately it isn't - coming together Confused
Looks like I'm going to have to came at this from another angle.....
When I click on "External Storage" (as per my OP) and I get the list of folders (as opposed to my NAS's - which are easily accesible by other means - WTF?)
One of the folders in that list is entitled "Pictures" - maybe if I could place my background jpeg in THAT folder - job sorted.
Any Ideas how to do that - exactly ??
