Dist: Gentoo 2007.0 fully updated
Arch: i686
Install method: manual/ebuild
SVN Revision: 13982
Whenever I try to play a mp3 xbmc crashes with segmentation fault.
Debug log
Backtrace
Specs
CPU0: Intel® Pentium® 4 CPU 3.00GHz
CPU1: Intel® Pentium® 4 CPU 3.00GHz
RAM: 1Gb
Kerne: Linux Genesis 2.6.24-gentoo-r4 #1 SMP
I have tried vith several other mp3's. and still segfault
Video Playback works fine.
if more info is needed. please tell me.
Hmm... when trying some flac files I get this error
ALSA lib pcm_dmix.c:996
snd_pcm_dmix_open) unable to open slave
Don't know why yet...but I'll keep on googling
And Im now up to Rev 13986.
wish me luck
Suddenly FLAC playback works...
but mp3 still segfaults...=(
Can you try to rebuild with USE=debug and repost your backtrace? Also, make sure the file /usr/local/share/xbmc/system/players/paplayer/MADCodec-i486-linux.so exists.
Thnx althekiller for taking a look.
Here's the
backtrace
And the
debug log again
And yes MADCodec-i486-linux.so exists in
/usr/share/xbmc/system/players/paplayer/MADCodec-i486-linux.so
I made an strace to but ended up with 51Mb textfile.
if it could be of intrest just poke me.
Here's a link to the
strace log
Enjoy
Hmm, seems the ebuild doesn't handle the debug flag properly. Any chance you can grab sources and compile yourself?
np give me an hour
althekiller Wrote:Hmm, seems the ebuild doesn't handle the debug flag properly. Any chance you can grab sources and compile yourself?
hmm... when you say it I think I used the xbmc bin which is just a bash script that runs /usr/share/xbmc/xbmc.bin -q
will try the xbmc.bin directly
here's the full output of gdb when I run /path/to /xbmc.bin directly and I see the debug info on the top
gdb bt
and why not yet another
logfile
Ok this is what makes things intressting. ^^
I downloaded it again as a regular user run build.sh enabled debug in settings -> System
played an mp3 file and got "ALSA lib pcm_dmix.c:996: (snd_pcm_dmix_open) unable to open slave"
well it does'nt segfault anymore
and I used the same rev as my system wide installation
The
logfile
any clues someone...
You either have a bad ~/.asoundrc file or something has a lock on your output device.
tought so too...but movies play fine and using external app works fine....even the klick sound when walking trough the menus work fine...
Well, I'l poke around little more
I'd go with what Al said, pretty sure it's a bad .asoundrc file. See my post
here
