2009-02-22, 19:07
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
2009-02-24, 20:58
Yes,
I have the same problem as you. Some days ago I found out that the youtube site is not working anymore.
If I select the file to show nothing happens. I think the problem comes with the clipnabber procedure, am I right.
cu Tom
cu Tom
2009-02-24, 21:03
Hi sfxman,
can you post a description on how we can help you fixing these problems inside the videomonkey, for youtube and the others
That would help us understanding the procedures and help you out of your timeproblem !!!
cu Tom
cu Tom
2009-03-02, 00:32
most of the problems should be fixed now (youtube, dailymotion, metacafe and googlevideo work for me on xbox... I didn't any tests on the other platforms ).
May be you will need to use a newer XBMC build
bye,
sfaxman...
bye,
sfaxman...
2009-03-03, 00:02
thnx for the fix! ^^
2009-03-03, 05:25
Do you have a thread for VideoDevil? Only a couple of the sites work. Thanks.
2009-03-03, 06:03
Youtube works great on this plugin. Thanks for the work.
2009-03-08, 04:22
am i the only one having issues with the Youtube plugin?
i get the directory loading for ages.
im sure it was working great a few nights ago?
anyone know the problem?
is there anyother youtube plugin that is working at the moment?
2009-03-08, 05:15
Did you update you release of XBMC?
Otherwise, yes there are at least 2 youtube plugin (one for video, one for channel) and one script (do a search on the forum to fin the topic and I also made them available via the Installer Passion-XBMC script).
But I don't see any reason why it shouldn't work with videoMonkey. Do you have anly logs showing the pb? It would help sfaxman to understand what is the issue.
2009-03-08, 05:34
i have done a update.
i noticed there used to be a update button in video monkey but that seems to have been removed in recent releases.
Everything in videomonkey works except youtube lol just my luck as thats the only thing i want to use.
When i click youtube, i just get videomonkey dicectory
Retrieved 0 items and seems to freeze.
its strange because i had it working the other day, i think i may have reinstalled xbmc since then.
I dont knwo where the log files are kept but id be happy to post mine.
im using windows vista 64 bit with xbmc 8.10
2009-03-08, 05:50
On which platform are you running XBMC?
I am asking because log location depend on the platform, here it is:
It is possible your issue is a compatibility problem between the script and your version of XBMC, but it should be the same with everything not only YouTube. Hopefully logs will give more info.
[edit] : my mistake I read too fast, you already mentioned you are on windows vista 64.
- XBOX: XBMC\xbmc.log
- Windows XP: C:\Documents and Settings\USERNAME\Application Data\XBMC\xbmc.log or sometimes still in XBMC\xbmc.log
- Windows VISTA: C:\Documents and Settings\USERNAME\AppData\Roaming\XBMC\xbmc.log or sometimes still in XBMC\xbmc.log
- MacOSX: /Users/USERNAME/Library/Logs/xbmc.log
- Linux: /var/tmp/xbmc.log
2009-03-08, 06:53
23:47:55 T:3092 M:2545586176 NOTICE: -->Python Interpreter Initialized<--
23:47:55 T:3092 M:2543620096 NOTICE: VideoMonkey debug logging enabled
23:47:55 T:3092 M:2543620096 NOTICE: Initializing VideoMonkey
23:47:55 T:3092 M:2543620096 NOTICE: VideoMonkey initialized
23:47:55 T:3092 M:2543620096 NOTICE: VideoMonkey running
23:47:55 T:3092 M:2543620096 NOTICE: 'title:GoogleVideo|type:rss|director:GoogleVideo|icon:googlevideo.png|genre:VideoMonkey|url:googlevideo.com.cfg'
23:47:55 T:3092 M:2543616000 NOTICE: googlevideo.com.cfg
23:47:55 T:3092 M:2543607808 NOTICE: Local file C:\Program Files (x86)\XBMC\plugins\video\VideoMonkey\resources\googlevideo.com.cfg opened
23:47:55 T:3092 M:2543607808 NOTICE: u'http://video.google.com/videorankings?type=hot'
23:47:56 T:3092 M:2542718976 NOTICE: Remote URL http://video.google.com/videorankings?type=hot opened
23:47:56 T:3092 M:2544390144 NOTICE: End of directory
23:48:08 T:4940 M:2540355584 NOTICE: -->Python Interpreter Initialized<--
23:48:08 T:4940 M:2537689088 NOTICE: VideoMonkey debug logging enabled
23:48:08 T:4940 M:2537689088 NOTICE: Initializing VideoMonkey
23:48:08 T:4940 M:2537689088 NOTICE: VideoMonkey initialized
23:48:08 T:4940 M:2537689088 NOTICE: VideoMonkey running
23:48:08 T:4940 M:2537689088 NOTICE: 'title: More |type:rss|genre:VideoMonkey|director:VideoMonkey|iconites.png|url:more.sites.list'
23:48:08 T:4940 M:2537684992 NOTICE: more.sites.list
23:48:08 T:4940 M:2537680896 NOTICE: Local file C:\Program Files (x86)\XBMC\plugins\video\VideoMonkey\resources\more.sites.list opened
23:48:08 T:4940 M:2537676800 NOTICE: End of directory
23:48:10 T:4560 M:2539061248 NOTICE: -->Python Interpreter Initialized<--
23:48:10 T:4560 M:2537177088 NOTICE: VideoMonkey debug logging enabled
23:48:10 T:4560 M:2537172992 NOTICE: Initializing VideoMonkey
23:48:10 T:4560 M:2537172992 NOTICE: VideoMonkey initialized
23:48:10 T:4560 M:2537168896 NOTICE: VideoMonkey running
23:48:10 T:4560 M:2537168896 NOTICE: 'title:YouTube|type:rss|director:YouTube|icon:youtube.png|genre:VideoMonkey|url:youtube.com.cfg'
23:48:10 T:4560 M:2537164800 NOTICE: youtube.com.cfg
23:48:10 T:4560 M:2537156608 NOTICE: Local file C:\Program Files (x86)\XBMC\plugins\video\VideoMonkey\resources\youtube.com.cfg opened
23:48:10 T:4560 M:2537160704 NOTICE: u'http://www.youtube.com/browse'
23:48:12 T:4560 M:2535297024 NOTICE: Remote URL http://www.youtube.com/browse opened
23:49:14 T:5256 M:2536386560 NOTICE: Storing total System Uptime
23:49:14 T:5256 M:2536386560 NOTICE: Saving settings
23:49:14 T:5256 M:2536345600 NOTICE: stop all
23:49:14 T:5256 M:2536345600 NOTICE: ES: Stopping event server
23:49:14 T:168 M:2536460288 NOTICE: ES: UDP Event server stopped
23:49:14 T:5256 M:2536493056 NOTICE: stop dvd detect media
23:49:14 T:5256 M:2536525824 NOTICE: stop sap announcement listener
23:49:14 T:5256 M:2536525824 NOTICE: clean cached files!
23:49:14 T:5256 M:2536525824 NOTICE: unload skin
23:49:14 T:5256 M:2548264960 NOTICE: stop python
Google Video works and youtube crashes.
2009-03-08, 07:53
I just tested on an Xbox with the last T3CH (and even with an old Beta2) and I have similar problems (xbmc blocks trying to retrieve the list and any action is impossible) when I go on Youtube, but the logs don't give too much info, here are mine (debug mode was activated):
00:48:16 M: 40558592 NOTICE: -->Python Initialized<--
00:48:16 M: 40558592 DEBUG: new python thread created. id=3
00:48:16 M: 40034304 DEBUG: DIRECTORY::CPluginDirectory::WaitOnScriptResult - waiting on the VideoMonkey plugin...
00:48:16 M: 40034304 DEBUG: Python thread: start processing
00:48:16 M: 40034304 DEBUG: XBPyThread::Process - The source file to load is special://home/plugins/video/VideoMonkey/default.py
00:48:16 M: 40034304 DEBUG: XBPyThread::Process - Setting the Python path to Q:\plugins\video\VideoMonkey;Q:\system\python\python24.zlib;Q:\system\python\DLLs;Q:\system\python\Lib;Q:\system\python\spyce
00:48:16 M: 40034304 DEBUG: XBPyThread::Process - Entering source directory Q:\plugins\video\VideoMonkey
00:48:16 M: 39084032 INFO: Loading skin file: DialogBusy.xml
00:48:16 M: 38936576 DEBUG: Load DialogBusy.xml: 93.00ms
00:48:16 M: 38936576 DEBUG: Alloc resources: 139.62ms (139.62 ms skin load, 0.00 ms preload)
00:48:16 M: 38797312 DEBUG: LoadLibraryExA called with flags:
- LOAD_WITH_ALTERED_SEARCH_PATH
00:48:16 M: 38797312 DEBUG: LoadLibraryA('_socket.pyd')
00:48:17 M: 38748160 DEBUG: kernel32.dll fake function DisableThreadLibraryCalls called
00:48:17 M: 38748160 DEBUG: LoadLibrary('_socket.pyd') returning: 00C69D40
00:48:17 M: 38748160 DEBUG: dllGetProcAddress(1E1D0000(_socket.pyd), 'init_socket') => 1E1D4BF0
00:48:17 M: 38731776 DEBUG: LoadLibraryExA called with flags:
00:48:17 M: 38731776 DEBUG: LoadLibraryA('_ssl.pyd')
00:48:17 M: 38236160 DEBUG: Unable to resolve msvcr71.dll _getch
00:48:17 M: 38236160 DEBUG: Unable to resolve kernel32.dll FlushConsoleInputBuffer
00:48:17 M: 38236160 DEBUG: kernel32.dll fake function DisableThreadLibraryCalls called
00:48:17 M: 38236160 DEBUG: LoadLibrary('_ssl.pyd') returning: 008C2710
00:48:17 M: 38236160 DEBUG: dllGetProcAddress(01580000(_ssl.pyd), 'init_ssl') => 01581820
00:48:17 M: 38227968 DEBUG: kernel32.dll fake function SetConsoleCtrlHandler called
00:48:17 M: 38055936 INFO: Loading skin file: DialogProgress.xml
00:48:17 M: 38109184 DEBUG: Load DialogProgress.xml: 109.66ms
00:48:18 M: 38068224 DEBUG: Alloc resources: 22.96ms (0.00 ms skin load, 1.39 ms preload)
00:48:18 M: 37797888 DEBUG: dllGetProcAddress(007EB8A0(advapi32.dll), 'CryptAcquireContextA') => 002406BD
00:48:18 M: 37797888 DEBUG: dllGetProcAddress(007EB8A0(advapi32.dll), 'CryptGenRandom') => 0023DD0D
00:48:18 M: 37797888 DEBUG: advapi32.dll fake function dllCryptAcquireContext() called
00:48:19 M: 36757504 DEBUG: LoadLibraryExA called with flags:
00:48:19 M: 36757504 DEBUG: LoadLibraryA('unicodedata.pyd')
00:48:19 M: 36347904 DEBUG: kernel32.dll fake function DisableThreadLibraryCalls called
00:48:19 M: 36347904 DEBUG: LoadLibrary('unicodedata.pyd') returning: 00D3D660
00:48:19 M: 36347904 DEBUG: dllGetProcAddress(1D120000(unicodedata.pyd), 'initunicodedata') => 1D1224F0
00:48:20 M: 36327424 DEBUG: LoadLibraryA('ws2_32')
00:48:20 M: 36327424 DEBUG: LoadLibrary('ws2_32.dll') returning: 007EAFF0
00:48:20 M: 36327424 DEBUG: dllGetProcAddress(007EAFB0(ws2_32.dll), 'getaddrinfo') => 0023DCE8
00:48:20 M: 36327424 DEBUG: dllGetProcAddress(007EAFB0(ws2_32.dll), 'getnameinfo') => 0023D3E6
00:48:20 M: 36327424 DEBUG: dllGetProcAddress(007EAFB0(ws2_32.dll), 'freeaddrinfo') => 0023CF5A
2009-03-08, 09:16
Quote:I just tested on an Xbox with the last T3CH (and even with an old Beta2) and I have similar problems (xbmc blocks trying to retrieve the list and any action is impossible) when I go on Youtube, but the logs don't give too much info, here are mine (debug mode was activated):
does this mean its server issue? and not likey to be something i can fix on my end?
Iv tried Reinstalling both xbmc and tried installing the plugin manualy.
Hopefully this can be resolved soon as i really liked the youtube fuction in this app.
Any tips on things to try?
2009-03-08, 12:23
"When i click youtube, i just get videomonkey dicectory
Retrieved 0 items and seems to freeze."
same here, i tried :
deleted XBMC on console, deleted both 0face008 folders
downloaded XBMC-SVN_2009-03-04_rev18221-T3CH
VideoMonkey.zip Updated Mar 2, 2009
uploaded xbmc, VideoMonkey
xbmc works, most of VideoMonkey works (for example 3sat, dailymotion), but youtube hangs the console
can it be region related? When I connect to youtube in a browser for the first time it asks me for a region selection as I am from non English speaking country (youtube recognizes it from my IP). Youtube wont work untill I click what country I want it to default on.
Quote:Close
Welcome to YouTube!
Suggested Country Filter (we have set your preference to this): Poland
The country filter shows you popular videos from the selected country on lists like Most Viewed and in search results. To change your country filter, please use the links next to the YouTube logo at the top of the page.
Click "OK" to accept this setting or click "Cancel" to set your country filter to "Worldwide (All)".
OK Cancel
