2009-10-04, 21:18
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
2009-10-05, 13:57
Thanks for this great plugin amigo.
I'm hitting a few python error boxes in some sections now - usually during searches and after it's found some results....for example veoh does it with some searches but not others....but there are other places I'm meeting similar errors. I'm on the latest XBMC build.
Anyway I'll need to wait until I get back to my xbox to be able to play with it and give you a more detailed error report.
Thanks for the great work though bro, and I look forward to an update.
And in English basically it says thanks for producing the translation and how can I include accents when searching for things as the keyboard on the xbox doesn't include them :-)
Quote:Para Drclone,
Gracias por traduciéndolo amigo. Voy a usar tu traducción. Pero quizás puedas ayudarme con un problema. No sé como puedo escribir los acentos porque no veo una opción cuando esté buscando. Suelo buscar por vídeos en español y por eso tengo que incluir la palabra 'español'....pero cuando busce en el xbox no puedo escribirlo y pues tengo que escribir sólo una parte de la palabra como 'espa'.... ¿Sabes comó pueda escribir los acentos? Espero que puedas entenderme, llevo más o menos 4 meses hablando español pues probablemente he cometido muchos errores!
2009-10-07, 20:15
sorry to just hop in here.
i'm on xbmc for mac and tried a few times to get the monkey to work... whenever i click on tv or live there are no items displaying..is that a mac issue or is the plugin not functioning correctly atm?
i just updated to the newest version but still have the same issue, i'll delete it now and reinstall, hopefuly that's gonna fix it! i'd really love to use the zdf mediathek, that would be awesome!
2009-10-09, 17:11
Is this script broken? I can´t get it to work anymore.
/sonic
/sonic
2009-10-09, 17:56
yep, broken atm. they changed something in the python routine or so...
2009-10-09, 21:08
Bootsy Wrote:yep, broken atm. they changed something in the python routine or so...
i hope it will be fixed soon. this is one of the few plugins i never want to miss.
btw is there still an active development? for a quite long time there were no updates.
$ svn info http://xbmc-addons.googlecode.com/svn/trunk/plugins/video/VideoMonkey/
Pfad: VideoMonkey
URL: http://xbmc-addons.googlecode.com/svn/trunk/plugins/video/VideoMonkey
Basis des Projektarchivs: http://xbmc-addons.googlecode.com/svn
UUID des Projektarchivs: 753fbab9-553a-0410-a42e-33068982fbc4
Revision: 1344
Knotentyp: Verzeichnis
Letzter Autor: bootsy82
Letzte geänderte Rev: 1135
Letztes Änderungsdatum: 2009-07-13 20:50:34 +0200 (Mo, 13. Jul 2009)
2009-10-10, 15:26
jackyohh Wrote:i hope it will be fixed soon. this is one of the few plugins i never want to miss.
Code:$ svn info http://xbmc-addons.googlecode.com/svn/trunk/plugins/video/VideoMonkey/
Pfad: VideoMonkey
Revision: 1344
i´m just doing some maintenance work on the plugins (monkey and devil), cuz sfaxman is busy. i´m not realy using videomonkey, so if i dont hear something about bugs and/or non-working parts of the plugin, i dont fix it cuz i dont know about it
Plus i´m also busy atm...
I dont know what they changed in xbmc now, i hope sfaxman will step in and fix it
greets
2009-10-10, 23:24
Bootsy Wrote:I dont know what they changed in xbmc now, i hope sfaxman will step in and fix it
Hello Bootsy,
If that might help, I've found that revision r22965 broke the plugin --
2009-10-11, 08:12
dbdl Wrote:Hello Bootsy,
yeap i config what bootsy found i reverted the diff form the 22965. And the plugins started to work back
2009-10-15, 13:54
Sfaxman & Bootsy : Do you guys have a solution on how to get this script or VideoDevil to work with the new python routine?
2009-10-15, 15:48
small request, could the default 'download path' F:\videos be removed from the plugin?
this folder is created each time i launch the plugin, even though the 'save video' option is disabled.
since i'm on linux, i don't have an F: drive, so i end up with this:
/home/xbmc/F:\videos
cheers!
cheers!
2009-10-15, 20:01
sonic Wrote:Sfaxman & Bootsy : Do you guys have a solution on how to get this script or VideoDevil to work with the new python routine?
nope, i´m on an older build...there are no problems
2009-10-16, 02:33
so there are no plans to upgrade the release for feature builds of xbmc?
pity
pity
2009-10-16, 17:28
mrchrister Wrote:so there are no plans to upgrade the release for feature builds of xbmc?
pity
dont start beeing hysteric :p
there will come an update...some day...but not today.
atm real life is more important than 'free time' coding
greetz
2009-10-17, 14:12
real life just made my head hurt ... first the beer than the vodka should have been the plan, not other way around!
anyway, i appreciate free time coding, thanks for at least givin me hope to be able to finally use the plugin one day
