as excuse for the broken PornHub
, i added PornoTube
sfaxman...
Oops, a small error has crept in. Fix will follow in few minutes.
Fixed
sfaxman...
Not all videos will play
I check tomorrow the reason.
Bye,
sfaxman...
Maybe you could categorize the "Live" and "TV" categories by country or language. I'm lovin your plugin. The amount of stream sources is growing rapidly and to have quick access to the streams you want (and keep it that way) folders for every country would be nice!
Once I find some time I'll try to add some Dutch streams (like uitzending gemist).
Yes... I think about organizing them by country and by genre (music, news, children...)
sfaxman...
VideoGoogle (en, fr, de, nl) added
Some RegEx are not optimal but it works
Bye,
sfaxman...
I've installed it and works fine. But when i try to use dailymotion doesn't work, if i try to search only says "Loading directory" and nothing happen. the other sites works fine. i don't know what i'm doing wrong but the thing is i can't see vids from dailymotion. Please helpme.
kof2k1zip Wrote:I've installed it and works fine. But when i try to use dailymotion doesn't work, if i try to search only says "Loading directory" and nothing happen. the other sites works fine. i don't know what i'm doing wrong but the thing is i can't see vids from dailymotion. Please helpme.
You're doing nothing wrong. Some RegEx for Dailymotion are outdated (page format changed
Take a look on the dailymotion cfg files). I will fix them asap.
Please use
this thread next time
sfaxman...
Would it be possible to add Joox support and an option to download vids instead of just streaming them?
Thanks, great pluging!
Dailymotion is fixed
(The search word suggestions are regrettably gone
Windows seems to have problems with "socket.setdefaulttimeout"
. So windows users should for now comment or remove line 28 of the default.py file.
Bye,
sfaxman...
SmokeySlim Wrote:Would it be possible to add Joox support and an option to download vids instead of just streaming them?
Video download is already realised (check the plugin settings
Joox will be investigated
sfaxman...
Oh yeah it is, cool!
And thanks
Hello, I just tried this in XBMC Linux and it crashes to the desktop. Does this not work in linux or did I miss something? Here is my log:
http://pastebin.com/m9f89073
Thank you
Hi sfaxman,
I installed this last night but when I tried to run it an error message occured - 'Cannot connect to Network Server'
I will update my T3CH release tonight, currently running 30-06-08 rev 13851
Could this be the problem?
Cheers,
redtrigger
