There are two shows which are not being scrapped i don't know why and previously i scrapped them :X
1st is Mirzapur (2018) Netflix Show
https://www.themoviedb.org/tv/84105-mirz...uage=en-US
2nd is Kaisi Yeh Yaariaan (2014) MTV Show
https://www.themoviedb.org/tv/63826-kais...uage=en-US
Please Help Guys when i scrap it nothing happens next , The TVDB Scrapped Mirzapur but it don't have details of Kaisi Yeh Yaariaan
its a big show almost 400+ Episodes can't add that much , i Added the details in The Movie DB and it was working flawlessly just after the reset of my Smart TV & Laptop Kodi ain't scrapping These Both Shows
) Help Please.
(2019-08-28, 08:21)Karellen Wrote: [ -> ]@dheerajpareek10
I can confirm your issue as I am unable to scrape the two shows either. This seems to be the same problem we had a week ago which we fixed with an update to the scraper.
You can scrape the two shows using a Parsing NFO file. See here... https://kodi.wiki/view/NFO_files#Parsing_nfo
@olympia is there another change at TheMovieDB? Line 1055... https://paste.kodi.tv/xuhefoyuza.kodi
Parsing NFO files cannot be used for episodes.
Its written in the link you gave and these two shows have those episodes so will it create problem or can be parsed ?
You don't use it for episodes. Use it for the TV Show. Then once the scraper finds the tv show from the parsing nfo, it will find the episodes.
(2019-08-28, 08:50)Karellen Wrote: [ -> ]You don't use it for episodes. Use it for the TV Show. Then once the scraper finds the tv show from the parsing nfo, it will find the episodes.
Well Karellen Thnx For Help But i Tried It maybe i am doing some Mistake Here Is What i am doing.
i have Mirzapur Folder Named With Mirzapur (2018)
Episodes Under it are named as : Mirzapur S01E01
Mirzapur S01E02
Mirzapur S01E03
etc.. upto 9 Episdoes.
i made a Nfo Named as Mirzapur (2018) in that nfo file i copied the name from The Movie DB
https://www.themoviedb.org/tv/84105-mirzapur
and saved the filed as NFO and copied into The Folder Of Mirzapur (2018).
tried to scrap nothing happened can u please help me out a bit xD i guess i am lost a bit in the process maybe doing some small mistake.
(2019-08-28, 09:16)dheerajpareek10 Wrote: [ -> ]i made a Nfo Named as Mirzapur (2018) in that nfo file i copied the name from The Movie DB
This is where you went wrong.
Name the nfo file as
tvshow.nfo and you place the
link into the file.
This link...
(2019-08-28, 09:22)Karellen Wrote: [ -> ] (2019-08-28, 09:16)dheerajpareek10 Wrote: [ -> ]i made a Nfo Named as Mirzapur (2018) in that nfo file i copied the name from The Movie DB
Name the nfo file as tvshow.nfo and you place the link into the file.
This link... https://www.themoviedb.org/tv/84105-mirzapur
okay got it the tvshow name is Mirzapur , i went wrong with the (2018) the year ain't needed let me see
(2019-08-28, 09:54)dheerajpareek10 Wrote: [ -> ]okay got it the tvshow name is Mirzapur , i went wrong with the (2018) the year ain't needed let me see
No, no. The file is named
tvshow.nfo Don't change it. This is the name of the file.
This is wrong - Mirzapur.nfo
This is wrong - Mirzapur (2018).nfo
This is correct -
tvshow.nfo
Please read the wiki...
https://kodi.wiki/view/NFO_files/TV_shows
Uh Karellen A Small problem i renamed that file as tvshow.nfo , i pasted the link also but same problem.
Well do i need change the content to local info ? i tried it din't worked.
Do you have the correct scraper active?
The link is for TheMovieDB, so you need TheMovieDB-TV Shows scraper set. Maybe you still have TVDB scraper set for the Source?
(2019-08-28, 10:12)Karellen Wrote: [ -> ]Do you have the correct scraper active?
nah its set to The Movie DB , i check it in the morning after it din't scrapped then The TV DB scrapped but again shifted to TMDB as my whole library is depended on TMDB 185 Shows.
By The Way Just Scrapped 150+ Shows No Problem occurred in them all scrapped easily without any name problems.
(2019-08-28, 10:13)dheerajpareek10 Wrote: [ -> ] (2019-08-28, 10:12)Karellen Wrote: [ -> ]Do you have the correct scraper active?
finally Worked cool , restarted Kodi and bang it worked
gonna try it for the second show too thnx Bro
amazing man
that's why i like Kodi you always handle my problems in every Support & Fourm Section and u always make sure you rectify it.
Hats Off Brother Thnx <3
Fantastic. Glad it is working. Otherwise I would have needed a log, and everybody hates doing that
