Full Version: xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs) causes exception
Hey there,
I'm currently porting script.skin.helper.colorpicker to support Python3 but I getting an init exception.
Is this a Matrix Py3 build bug or do I miss a Python3 change?
Init:
https://github.com/sualfred/script.skin....ult.py#L16
Dialog init:
https://github.com/sualfred/script.skin....ker.py#L92
Exception:
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <class 'TypeError'>
                                            Error Contents: object.__init__() takes no arguments
                                              File "C:\Users\su4lf\AppData\Roaming\Kodi\addons\script.skin.helper.colorpicker\default.py", line 65, in <module>
                                                Main()
                                              File "C:\Users\su4lf\AppData\Roaming\Kodi\addons\script.skin.helper.colorpicker\default.py", line 16, in __init__
                                                color_picker = cp.ColorPicker("script-skin_helper_service-ColorPicker.xml", ADDON_PATH, "Default", "1080i")
                                              File "C:\Users\su4lf\AppData\Roaming\Kodi\addons\script.skin.helper.colorpicker\resources\lib\ColorPicker.py", line 92, in __init__
                                            TypeError: object.__init__() takes no arguments
