Full Version: .ignore file inside bluray folder not functioning as it should
need to block a bluray (bdmv/certificate) folder from being picked up by the scraper.
should the .ignore file go inside the main folder  where  bdmv and certificate folders exist or should it go inside the bdmv folder?
It is broken for Bluray folders. Still works for DVD folders though, strangely.
I would recommend to put the complete BR folder structure into an ISO. Having an open BR folder structure can become a mess sometimes. Or probably create MKVs of those BRs. Then the scraper won't pick up anything else than the movie itself.
