https://i.imgur.com/dHGm8dV.png
TMM has it ordered right, but is there anyway to apply the episode numbers without having to go through each show and edit it?
nope.. tmm just needs a bit more info to do automatic work..
if you are able to mass-rename it (at least most linux file managers and macos finder are able to do that), you could inject some recognized season/episode patterns to the filename so that tmm knows how to do its work
(2019-08-31, 16:52)mlaggner Wrote: [ -> ]nope.. tmm just needs a bit more info to do automatic work..
Yep, mass renamed and worked out well. Thanks!
