2020-07-18, 21:50
(2020-07-18, 21:12)tromy Wrote: [ -> ]Are you using a combination of live and local channels? Or Just Local channels?(2020-07-18, 18:16)Lunatixz Wrote: [ -> ]No,I always use PVR Callback(2020-07-18, 17:52)tromy Wrote: [ -> ]After the last updates channel switching is slower than before.I think that started to happen after update f but I'm not so sure.In previous versions changing from one channel to another was too fast but now it takes about 4 sec.Guess that other users face the same issue and it's not something in my end.
Thank you
The only change was playlist queue size... are you using playlist playback?
I noticed this evening that the channels I created earlier today (Live and Local), was also causing a delay of 5-6 secs with my channel switches on the local channels. I only tested the channel switches on the live channels earlier today.
I then deleted my PTVL m3u, xmltv and settings file and started from scratch by selecting some new local channels only. Channels switches are now back to normal (like 1 sec).
Might be worth a try?
Edit: Soz, Lunatixz. I didn't see your response before I posted.
