2019-09-01, 14:16
Hi All,
I'm looking for an API set that I can parse through to understand what options are available? I've gone to http://<kodi IP>:8080/jsonrpc and I see json outlining what appears to be API calls I can make, but when I use what's listed here it doesn't respond.
some of the leads I've got from investigation is that the bottom the version reads 10.3.0, but whenever I run an API from this set it comes back with
hoping for someone to point me in the right direction.
which tells me the operating rpc version is 2.0. Another, is that when I look through this list of calls, there isn't one to set the volume.json:{"id":1,"jsonrpc":"2.0","result":{"version":{"major":18,"minor":3,"revision":"newclock5_18.3-Leia","tag":"stable"}}}
