Full Version: TMM in dropbox doesn't work in all computers
I have a problem that I really cann't understand.  Here is the fact:  I have 3 computers where I have on letter V:\ my google teamdrive with unlimited space, and I map that drive using Raidrive.
Since in all computers the source it is similar (V:\), I have installed TMM in dropbox, that way TMM is sincronized in the 3 computers.
My surprise came when TMM can be opened just in the first computer I "installed" TMM, but in the others it seems to open but in the middle of the process, it finished.
Since folder should be the same because it si syncronized with dropbox, I can not understand why it is not working.
I have tried with 3 or 4 TMM instances but I always get the same error.
This is the log file...
2019-09-04 00:03:29,646 INFO [main] org.tinymediamanager.TinyMediaManager:154 - =====================================================
2019-09-04 00:03:29,649 INFO [main] org.tinymediamanager.TinyMediaManager:155 - === tinyMediaManager © 2012-2019 Manuel Laggner ===
2019-09-04 00:03:29,649 INFO [main] org.tinymediamanager.TinyMediaManager:156 - =====================================================
2019-09-04 00:03:29,655 INFO [main] org.tinymediamanager.TinyMediaManager:157 - tmm.version : 3.0.4
2019-09-04 00:03:29,657 INFO [main] org.tinymediamanager.TinyMediaManager:158 - os.name : Windows 7
2019-09-04 00:03:29,657 INFO [main] org.tinymediamanager.TinyMediaManager:159 - os.version : 6.1
2019-09-04 00:03:29,657 INFO [main] org.tinymediamanager.TinyMediaManager:160 - os.arch : amd64
2019-09-04 00:03:29,658 INFO [main] org.tinymediamanager.TinyMediaManager:161 - java.version : 1.8.0_191
2019-09-04 00:03:29,658 INFO [main] org.tinymediamanager.TinyMediaManager:162 - java.maxMem : 1280 MiB
2019-09-04 00:03:33,152 INFO [main] org.tinymediamanager.TinyMediaManager:622 - current encoding : UTF-8 | UTF8 | UTF-8
2019-09-04 00:03:33,153 INFO [main] org.tinymediamanager.TinyMediaManager:179 - System language : es_ES
2019-09-04 00:03:33,153 INFO [main] org.tinymediamanager.TinyMediaManager:180 - GUI language : es_ES
2019-09-04 00:03:35,208 INFO [main] o.t.scraper.config.MediaProviderConfig:77 - load settings 'data\scraper_tmdb.conf'
2019-09-04 00:03:35,251 INFO [main] o.t.scraper.config.MediaProviderConfig:77 - load settings 'data\scraper_tvdb.conf'
2019-09-04 00:03:35,712 INFO [main] org.tinymediamanager.TinyMediaManager:181 - Scraper language : español
2019-09-04 00:03:36,098 INFO [main] org.tinymediamanager.TinyMediaManager:182 - TV Scraper lang : español
2019-09-04 00:03:49,520 INFO [main] org.tinymediamanager.TinyMediaManager:210 - =====================================================
2019-09-04 00:03:49,564 INFO [main] org.tinymediamanager.TinyMediaManager:238 - starting tinyMediaManager
2019-09-04 00:03:51,675 INFO [main] o.t.thirdparty.MediaInfoUtils:75 - Using MediaInfoLib - v19.04
2019-09-04 00:03:58,738 INFO [main] o.tinymediamanager.core.movie.MovieList:371 - found 3051 movies in database
2019-09-04 00:03:58,750 INFO [main] o.tinymediamanager.core.movie.MovieList:392 - found 427 movieSets in database
2019-09-04 00:03:59,570 ERROR [main] o.t.core.tvshow.TvShowModuleManager:87 - Error in the background thread of the persistent cache java.lang.IllegalStateException: File corrupted in chunk 12745, expected page length 4..768, got 626628462 [1.4.199/6] at org.h2.mvstore.DataUtils.newIllegalStateException(DataUtils.java:883) at org.h2.mvstore.MVStore.readBufferForPage(MVStore.java:1055) at org.h2.mvstore.MVStore.readPage(MVStore.java:2186) at org.h2.mvstore.MVMap.readPage(MVMap.java:554) at org.h2.mvstore.Page$NonLeaf.getChildPage(Page.java:1086) at org.h2.mvstore.Cursor.hasNext(Cursor.java:53) at org.h2.mvstore.MVStore.readStoreHeader(MVStore.java:793) at org.h2.mvstore.MVStore.<init>(MVStore.java:401) at org.h2.mvstore.MVStore$Builder.open(MVStore.java:3343) at org.tinymediamanager.core.tvshow.TvShowModuleManager.startUp(TvShowModuleManager.java:88) at org.tinymediamanager.core.TmmModuleManager.enableModule(TmmModuleManager.java:56) at org.tinymediamanager.TinyMediaManager$1.run(TinyMediaManager.java:279) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) 2019-09-04 00:03:59,571 ERROR [main] org.tinymediamanager.TinyMediaManager:383 - IllegalStateException java.lang.IllegalStateException: File corrupted in chunk 12745, expected page length 4..768, got 626628462 [1.4.199/6] at org.h2.mvstore.DataUtils.newIllegalStateException(DataUtils.java:883) at org.h2.mvstore.MVStore.readBufferForPage(MVStore.java:1055) at org.h2.mvstore.MVStore.readPage(MVStore.java:2186) at org.h2.mvstore.MVMap.readPage(MVMap.java:554) at org.h2.mvstore.Page$NonLeaf.getChildPage(Page.java:1086) at org.h2.mvstore.Cursor.hasNext(Cursor.java:53) at org.h2.mvstore.MVStore.readStoreHeader(MVStore.java:793) at org.h2.mvstore.MVStore.<init>(MVStore.java:401) at org.h2.mvstore.MVStore$Builder.open(MVStore.java:3343) at org.tinymediamanager.core.tvshow.TvShowModuleManager.startUp(TvShowModuleManager.java:88) at org.tinymediamanager.core.TmmModuleManager.enableModule(TmmModuleManager.java:56) at org.tinymediamanager.TinyMediaManager$1.run(TinyMediaManager.java:279) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$500(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.awt.EventQueue$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
dropbox uses no standard file system and the database engine looks like to have a problem with that..
I suppose there is no workaround for you
I use it with OneDrive (Microsoft) on different computers and it works like a charm :-)
Thanks.  I don't use Onedrive but will try with google drive.
Regards,
