2019-09-05, 14:18
2019-09-05, 14:18
2019-09-05, 14:26
Season 0 are for episode specials, and should have their own "Season 0" sub folder. Or do you simply dump all episodes of a TV show in a single folder?
And I don't know what your settings for TV shows are.
2019-09-05, 16:07
If you look at the date you'll find your answer - they're in the aired order.
2019-09-05, 17:07
(2019-09-05, 16:07)Hitcher Wrote: [ -> ]If you look at the date you'll find your answer - they're in the aired order.
Second screenshot shows they are in separate season folders
First shows I have selected episode order, not date order..
Does that help?
2019-09-05, 17:58
Yep, that's the order of the episodes.
2019-09-05, 17:58
(2019-09-05, 17:07)wcndave Wrote: [ -> ]Will not make a difference. If a special is aired before or after a scheduled episode the special will show at that time in your order.(2019-09-05, 16:07)Hitcher Wrote: [ -> ]If you look at the date you'll find your answer - they're in the aired order.
Does that help?
2019-09-05, 18:35
I'll change the dates in the nfo files then. Bit odd that you can't keep the specials separate from the main shows.
2019-09-05, 23:18
@wcndave
It is expected behaviour. Read here... https://forum.kodi.tv/showthread.php?tid...pid2706581
2019-09-06, 09:02
(2019-09-05, 23:18)Karellen Wrote: [ -> ]@wcndave
Thanks, I will use that to help me edit the nfo files.
On a more general note, and this could be more about source data, eg tvdb, rather than kodi, I do think that "air date" and "forms part of storyline narrative" are different, and there could to be a separate flag for it.
If you have 40 different "interview specials" for GoT season 2, you don't really want to see them in the list of episodes....
Fortunately it doesn't impact "next episode" functionality, although this is a bit inconsistent in some ways.
2019-09-06, 10:47
(2019-09-06, 09:02)wcndave Wrote: [ -> ]If you have 40 different "interview specials" for GoT season 2, you don't really want to see them in the list of episodes....If those come from DVD/Blu-ray release then they aren't specials but extras, specials refers purely to special episodes that have been broadcast and not supplementary stuff.
For extras they can be added with https://kodi.wiki/view/Add-on:Extras
