Full Version: Not at all Mainmenu Points shows me Fanarts
on LibreElec with Rapir i would shows me in the BAckground on the Mainmenu Fanarts, but on a few this dont work.
  • TV
  • Youtube
  • Musik
It Shows me on this Points the Globel Background
https://paste.kodi.tv/opubequvev.kodi
Hi Coolzero.
Have you set the correct fanart backgrounds in the skin settings > backgrounds?
I see you use script.skin.helper.backgrounds v1.0.21.
Try latest version (1.0.33) by manually downloading and installing from zip: https://github.com/kodi-community-addons...ackgrounds
Restart Kodi after install.
TV fanart doesn't really work for me either. It's not a skin problem, but I guess it depends on the channels and content.
Music requires that fanart is added for all artists in your library.
What do you mean with YouTube? Addon? Fanart? Category? Widget?
