hi all,
I'm trying to add a source for TFC
https://tinyurl.com/cmikRepoZip and I'm unable to see the data typed. after hitting continue, the system freezes.
here are my logs.
https://paste.kodi.tv/ofivojogog
iPhone XS Max
iOS 13.1
Kodi Build 18.4 Git:20190831-3ade758ceb
Compiled 2019-09-01
thanks
EDIT*****
I pulled out my trusty old iPad and installed the same build on iOS 12.4. everything is working as intended. it seems to be an issue with how iOS13.1 is behaving.
I’m having the same problem. Hopefully a fix will happen soon
Yes I am. IOS 13.1 beta 2 and it killed all my sources when I updated the IOS
I can reproduce too. Will try to fix.
(2019-09-07, 12:51)kambala Wrote: [ -> ]I can reproduce too. Will try to fix.
Great news. Thank you!!!
I just noticed the issue is present anywhere we can use the keyboard to type.
(2019-09-09, 05:23)Mannyp Wrote: [ -> ] (2019-09-07, 22:11)kambala Wrote: [ -> ]Please check if this build resolves the issue for you: https://jenkins.kodi.tv/job/IOS-ARM64/92...-ios64.deb
Opened PR: https://github.com/xbmc/xbmc/pull/16582
thank you so much! this build did fix the problem.
how does this work now? will this fix be incorporated into an official build at any point?
as soon as iOS 13 is released, I'll test 18.4 and merge PR into master if the bug is still there. If there will be 18.5, the fix will go there for sure, otherwise you'll have to stick to master builds (19 alpha).
(2019-09-09, 11:15)kambala Wrote: [ -> ] (2019-09-09, 05:23)Mannyp Wrote: [ -> ] (2019-09-07, 22:11)kambala Wrote: [ -> ]Please check if this build resolves the issue for you: https://jenkins.kodi.tv/job/IOS-ARM64/92...-ios64.deb
I'm getting an error when trying to download the fix
(2019-09-09, 18:43)Dsimpsonjuice Wrote: [ -> ] (2019-09-09, 11:15)kambala Wrote: [ -> ] (2019-09-09, 05:23)Mannyp Wrote: [ -> ]thank you so much! this build did fix the problem.
Also getting an error trying to download this build. Can you provide an open link or let us know if this is merged into the nightlies.
The error im getting is :
HTTP ERROR 403
Problem accessing /job/IOS-ARM64/9282/artifact/tools/darwin/packaging/ios/kodi-20190907-4d3a73b7-PR16582-merge-ios64.deb. Reason:
Trying to access a file outside of the directory, target: tools/darwin/packaging/ios/kodi-20190907-4d3a73b7-PR16582-merge-ios64.deb
