2020-08-17, 19:13
2020-09-18, 01:04
Where is the file manager?
I cant see to find it anywhere.
Really nice skin thou, just changed from the default and after such a long time its really refreshing to have something completely different....need that file manager thou.
Cheers
Cheers
2020-09-18, 01:22
@James_liv
Settings item in the main menu, press down arrow, you have now submenu items, is there the file manager.
Enjoy
Enjoy
2020-09-18, 01:25
@sagaopc
Go to customize main menu, change icons, look ?, will open explorer, point for the new icon, done.
2020-09-18, 01:28
(2020-09-18, 01:22)Wanilton Wrote: [ -> ]@James_liv
Enjoy
Brilliant. Thank you.
On another note. The HDR flag never shows. It always seems to say SDR. Is there something I need to do to get this to show?
Thanks again
2020-09-18, 02:12
2020-11-10, 06:05
I really like this skin but for the life of me I cannot figure out how to pull a widget from an add on. Most confusing skin I have tried. Liking to pull a widget from film on add on. Do you have a help video or documentation how this is done? Thanks!
2020-11-10, 06:19
(2020-11-10, 06:05)derrgoo123 Wrote: [ -> ]Liking to pull a widget from seren add onPlease be aware that is banned from this forum. If you have it installed, it makes you ineligible for support here.
2020-11-10, 08:31
(2020-11-10, 06:19)Karellen Wrote: [ -> ](2020-11-10, 06:05)derrgoo123 Wrote: [ -> ]Liking to pull a widget from seren add onPlease be aware that is banned from this forum. If you have it installed, it makes you ineligible for support here.
My bad. meant to say film on because I mostly use plex now and just a few add ons from kodi repo.
2020-11-10, 10:13
For clarity - any device which contains any banned addon (wiki) such as Seren is not eligible for any kind of support here.
See the piracy policy (wiki) section of the forum rules (wiki) for more detail.
2021-05-23, 20:25
I am using this skin since I discovered and like it more and more, but now I have some problems, after I installed a new image of CoreElec on my Kiii pro box
To be more exactly, I don't know how to enable view of actors and other info, after pressing button info.
Is there a documentation, or someone can tell me exactly steps I need to do to enable this?
I managed to do this:
Enabled option in skin settings : Info button opens extra information window via script extended info
Installed script.extended.info, Library Data Provider, The Movie DB Helper.
When I press info button, only summary comes, ni pictures...
Does anybody know how to do this?
It seems that skin author's email is not working, I tried to contact him bu the email returned with no available address message.
Unfortunately I have no other options to benefit from this skin (Ace 2) with all options...
I just don't understand message " ERROR: Control 600 in window 12140 has been asked to focus, but it can't" that appears when I press info button.
Maybe if I follow this I can find out what is wrong...
2021-05-25, 23:31
(2021-05-23, 20:25)GabrielD Wrote: [ -> ]Hi,
I will check with Marcos about it.
2021-05-26, 17:55
(2021-05-25, 23:31)Wanilton Wrote: [ -> ]Great news... I will look forward to find what he said...(2021-05-23, 20:25)GabrielD Wrote: [ -> ]Hi,
2021-05-27, 12:25
(2021-05-26, 17:55)GabrielD Wrote: [ -> ]Until Marcos will have time to answer, I just tested another skin Aeon MQ8 but still no actors images...(2021-05-25, 23:31)Wanilton Wrote: [ -> ]Great news... I will look forward to find what he said...(2021-05-23, 20:25)GabrielD Wrote: [ -> ]Hi,
It seems that I need to find out exactly what other addons or sripts should I install...
2021-05-27, 13:39
Do you install script extended info, it´s necessary to appear the actor's images.
