Full Version: Why do I have these duplicates?
Hello,
First of all, thank you for your wonderful program :-)
I am running 3.0.4.
I have the TV-series "St. Elsewhere". I deleted all *.nfo in all the subdirectories of this TV show, and then did "Update Sources".
In Season 02 it creates all kind of duplicates. Why is this?
(Also, in S01 it is missing a movie that is clearly there).
22 files in Total Commander: https://ibb.co/8BGYx53
The files in TMM: https://ibb.co/nBNhf6q
Notice that it also didn't create any *.nfo in the S02 directory.
Thank you for any help,
Bye,
Update works for me.
Please delete entire show from TMM, press update, and create a support logfile/bugreport...
Additionally, check the files in the mediainformation tab.
There must be 2 different files for S02E01...
(2019-09-09, 14:43)myron Wrote: [ -> ]Update works for me.
Thank you for your reply.
I choose 'remove' instead of delete, as I don't want to physically delete the files from my media server.
I then did 'update sources'.
Now, for some vague unknown reason, it is mixing S01 and S02, although in the directory there are only S02 files.
And the same duplicates, even triplicates, now in the left part of the screen:
https://ibb.co/X4MCxBN
Whereas my physical directory still is:
https://ibb.co/VBSDs76
As to the support/debug log: is this it? : Tools/Export logs for debugging?
Where do I send these files to for you to check them? I can't attach it to this post.
Thank you again,
Bye,
could you open a new issue at https://gitlab.com/tinyMediaManager/tinyMediaManager along with your screens and the log? (basically what happens if you report a bug out of tmm)
