Full Version: SUB/IDX Renaming Bug
I've been having issues with subtitles not showing up in Kodi after I've used tinymm to grab all the media info, generate nfo files and rename everything.  After a bit of digging around it seems that tmm is renaming *.sub files appropriately but the *.idx file is not being renamed in the same way.  A portion of the old filename is being retained and that's causing the subtitles not to be found.
Example:
I have an episode of The Crown with subtitles as follows;
TheCrown.S01E02.HydeParkCorner.DTS.720P.mkv
TheCrown.S01E02.HydeParkCorner.DTS.720P.sub
TheCrown.S01E02.HydeParkCorner.DTS.720P.idx
After running it through Tiny Media Manager i'll find the files like this:
The Crown - S01E02 - Hyde Park Corner.mkv
The Crown - S01E02 - Hyde Park Corner.eng.sub
The Crown - S01E02 - Hyde Park Corner.DTS.720P.idx
As everything isn't named consistently the subs aren't picked up.  Anyone else having this issue?
Thx, but already fixed for next version.
https://gitlab.com/tinyMediaManager/tiny...issues/635
(2019-09-13, 20:37)myron Wrote: [ -> ]Thx, but already fixed for next version.
Excellent.  Thanks. Smile
