2019-11-17, 19:52
2019-11-23, 06:53
It ia really a pity no one is interesting in this device.
Could someone got it tell us something?
PQ, deinterlace, upscaling, hd audio passtrough etc..
2019-11-23, 12:19
(2019-11-23, 06:53)antony23 Wrote: [ -> ]It ia really a pity no one is interesting in this device.No HD áudio passthrough.
(2019-11-17, 19:52)kwanbis Wrote: [ -> ]Does it support NTFS? I have a FireTV Stick and it doesn't.
If you want to watch movies just plug the NTFS hdd into the router and access it from the fire TV Stick/Cube that you will read.
2019-11-25, 16:33
(2019-11-03, 17:23)fritsch Wrote: [ -> ]I am curious if someone could test my forceraw build on this device to see if it supports dts-hd / truehd via this "alternative" method. Just building it, will result here: http://mirrors.kodi.tv/test-builds/android/arm/ with forceraw in name. Curious.
Hello,
since Saturday I am an owner of a Fire TV Cube. The forceraw don´t work for me. Kodi show me DTS-HD but when I try to play a movie in DTS-HD I can´t hear anything.
Just for fun I tried Kodi 19. Here DTS-HD with my Cube worked fine .
2019-11-25, 16:36
Cool :-)
Could you post me the Debug Log? In v19 alphas I implemented a feature that DTS-HD-HR and DTS-HD-MA are distinguished. My Firetv 4k for example can only do DTS-HD-HR. For DTS-HD-MA I automatically fall back to the DTS-Core.
Nice, that you like it.
Btw. do you also have this "Stereo" delay issue as others reported? Does your box also automatically do "DD encoding" and outputting 5.1 if you want Stereo output?
2019-11-25, 19:46
Hello Fritsch,
please find the Link to the debug log (Kodi 18.4 - forceraw):
https://paste.kodi.tv/awecirofak.kodi
I also tested kodi 19 again. On the the Cube it´s the same: DTS-HD-HR is playing and DTS-HD-MA is fallback to DTS.
Yes Kodi (18.5) does automatically do "DD encoding" when I want Stereo, but I don´t have any delay.
2019-11-25, 19:48
The "DD" is a feature from FireTV by itself. Even if you select 2 channels in kodi, menu sounds and so on are transcoded by FireTV itself to AC3.
Okay - when I watch certain movies on my FireTV 4K with stereo sound I get ~ 150 ms delay. So - that is "somehow fixed" on the cube? :-)
2019-11-25, 19:52
Looking at your log: They don't seem to implement the IEC format anymore. This heavily sucks :-( - as we need to output via the inferior RAW format.
Could you give me a Debug Log with this one, please: http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk (adb install -r kodi-20191125-dc37495a-fritschfiretv-armeabi-v7a.apk after you are connected.)
Please test DTS-HD, EAC3, also check if they are in sync in comparison to the 18.4 you are currently running.
^^ that should not really work for you as is I think.
Quote:2019-11-25 17:45:47.160 T:8696 WARNING: ActiveAE - large audio sync error: 1797.848999
2019-11-25 17:45:47.160 T:8696 WARNING: ActiveAE - large audio sync error: 1797.063708
2019-11-25 17:45:47.160 T:8696 WARNING: ActiveAE - large audio sync error: 1797.370041
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1861.591999
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1860.883083
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1861.190208
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1861.500833
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1860.813125
2019-11-25 17:45:47.161 T:8696 WARNING: ActiveAE - large audio sync error: 1861.125625
2019-11-25, 21:14
(2019-11-25, 19:48)fritsch Wrote: [ -> ]The "DD" is a feature from FireTV by itself. Even if you select 2 channels in kodi, menu sounds and so on are transcoded by FireTV itself to AC3.
Hello,
it´s a little bit funny.
Test 1:
Sound Settings Cube: "Automatic"
Kodi: Number of channels 2.0
Kodi plays eveything in Dolby Digital 2.0
Test 2:
Sound Settings cube: Only Stereo
Kodi: Number of channels 2.0 or 5.1 doens´t matter.
Kodi is playing everything in "Multich PCM 7.1". Passthrough settings disappear.
As I said I have no problems with any delay.
2019-11-25, 21:17
(2019-11-25, 19:52)fritsch Wrote: [ -> ]Looking at your log: They don't seem to implement the IEC format anymore. This heavily sucks :-( - as we need to output via the inferior RAW format.Hi,
I will stay with this Version. It works. DTS HR is playing without problems. DTS MA fallback to DTS. It seem everything is fine with this version.
https://paste.kodi.tv/arubulereq.kodi
2019-11-25, 21:18
Edit: This was the reply to: https://forum.kodi.tv/showthread.php?tid...pid2903237
Okay. Thanks. From your log it looked not so good, but if you are happy - let's keep you happy :-)
I will debug the RAW formats a bit the next days, to not break too much with upcoming v19 next year.
2019-11-25, 21:21
okay. If you want me to test other versions in future let me know.
2019-11-25, 21:22
Now reply to your latest post: https://forum.kodi.tv/showthread.php?tid...pid2903238
Good news :-) with that version IEC format works properly. You want to know the reason? In v18 - there was a 5 year old hack for amlogic hackarounds integrated. This I dropped for v19 and - in your above build - I backported it :-)
Great ...
Quote:2019-11-25 19:52:54.792 T:22464 NOTICE: Float is supported
2019-11-25 19:52:54.792 T:22464 NOTICE: Multi channel Float is supported
2019-11-25 19:52:54.792 T:22464 DEBUG: AESinkAUDIOTRACK - 32000 supported
2019-11-25 19:52:54.793 T:22464 DEBUG: AESinkAUDIOTRACK - 44100 supported
2019-11-25 19:52:54.793 T:22464 DEBUG: AESinkAUDIOTRACK - 48000 supported
2019-11-25 19:52:54.793 T:22464 DEBUG: AESinkAUDIOTRACK - 88200 supported
2019-11-25 19:52:54.794 T:22464 DEBUG: AESinkAUDIOTRACK - 96000 supported
2019-11-25 19:52:54.794 T:22464 DEBUG: AESinkAUDIOTRACK - 176400 supported
2019-11-25 19:52:54.794 T:22464 DEBUG: AESinkAUDIOTRACK - 192000 supported
2019-11-25 19:52:54.861 T:22464 DEBUG: Firmware implements AC3 RAW
2019-11-25 19:52:54.925 T:22464 DEBUG: Firmware implements EAC3 RAW
2019-11-25 19:52:55.001 T:22464 DEBUG: Firmware implements DTS RAW
2019-11-25 19:52:55.089 T:22464 DEBUG: Firmware implements DTS-HD RAW
2019-11-25 19:52:55.164 T:22464 DEBUG: AESinkAUDIOTrack: Using IEC PT mode: 13
2019-11-25 19:52:55.164 T:22464 DEBUG: AC3 and DTS via IEC61937 is supported
2019-11-25 19:52:55.268 T:22464 DEBUG: E-AC3 and DTSHD-HR via IEC61937 is supported
2019-11-25 19:52:55.271 T:22464 INFO: AESinkAUDIOTRACK - AudioTrack creation (channelMask 0x000018fc): java.lang.IllegalArgumentException: ENCODING_IEC61937 must be configured as CHANNEL_OUT_STEREO
2019-11-25 19:52:55.321 T:22464 NOTICE: Found 1 Lists of Devices
2019-11-25 19:52:55.321 T:22464 NOTICE: Enumerated AUDIOTRACK devices:
2019-11-25 19:52:55.321 T:22464 NOTICE: Device 1
2019-11-25 19:52:55.321 T:22464 NOTICE: m_deviceName : AudioTrack
2019-11-25 19:52:55.321 T:22464 NOTICE: m_displayName : android
2019-11-25 19:52:55.321 T:22464 NOTICE: m_displayNameExtra: audiotrack
2019-11-25 19:52:55.321 T:22464 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2019-11-25 19:52:55.321 T:22464 NOTICE: m_channels : FL, FR, FC, LFE, SL, SR, BL, BR, BC, BLOC, BROC
2019-11-25 19:52:55.321 T:22464 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2019-11-25 19:52:55.321 T:22464 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT,AE_FMT_RAW,AE_FMT_RAW
2019-11-25 19:52:55.321 T:22464 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD
Great ...
2019-11-25, 21:22
(2019-11-25, 21:21)nomox22 Wrote: [ -> ] okay. If you want me to test other versions in future let me know.
All fine :-) I need to think about a real solution so that official kodi v18 is not horribly broken on the cube, because of the old AMLOGIC hack ...
2019-11-25, 22:56
I pushed a newer version, fixing some minors in Deinitialize code: http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk - other than that all the same.
