Full Version: Bug - settings not being saved
I'm currently running version 3.0.5-SNAPSHOT with a build date of 2019-09-18 00:24
When I go into Settings -> TV shows -> Renamer, under the Advanced options there is a setting for "Replace colons with" and you can either select blank or underscore (_).  When I pick the underscore and close out settings and the app, then reopen the app, the setting has been changed back to blank.
thanks, will be fixed in the next version (nightly tomorrow, release 3.0.5)
