2019-09-19, 23:32
Hello,
Today, the media manager does not start anymore?
2019/09/19 23:30:28:144 INFORMATION Using appdir from command line: .
2019/09/19 23:30:28:144 INFORMATION Using appbase from system property: https://www.tinymediamanager.org/
2019/09/19 23:30:28:145 INFORMATION ------------------ VM Info ------------------
2019/09/19 23:30:28:145 INFORMATION -- OS Name: Windows 10
2019/09/19 23:30:28:145 INFORMATION -- OS Arch: x86
2019/09/19 23:30:28:145 INFORMATION -- OS Vers: 10.0
2019/09/19 23:30:28:145 INFORMATION -- Java Vers: 1.8.0_221
2019/09/19 23:30:28:145 INFORMATION -- Java Home: C:\Program Files (x86)\Java\jre1.8.0_221
2019/09/19 23:30:28:145 INFORMATION -- User Name: swenw
2019/09/19 23:30:28:145 INFORMATION -- User Home: C:\Users\swenw
2019/09/19 23:30:28:145 INFORMATION -- Cur dir: D:\Tiny-Media
2019/09/19 23:30:28:145 INFORMATION ---------------------------------------------
2019/09/19 23:30:28:161 INFORMATION Getdown starting [version=1.8.3-SNAPSHOT, built=2019-02-26 14:29]
2019/09/19 23:30:28:164 INFORMATION Failed to find proxy settings in Windows registry [error=java.lang.UnsatisfiedLinkError: no jRegistryKey in java.library.path]
2019/09/19 23:30:28:165 INFORMATION Checking whether we need to use a proxy...
2019/09/19 23:30:28:251 INFORMATION Downloading 0 resources [totalBytes=0, maxConcurrent=7]
2019/09/19 23:30:28:253 INFORMATION Dropping status 'm.resolving'.
2019/09/19 23:30:28:254 INFORMATION Dropping status 'm.downloading'.
2019/09/19 23:30:28:254 INFORMATION Dropping status 'm.detecting_proxy'.
2019/09/19 23:30:28:254 INFORMATION Testing whether proxy is needed, via: http://release.tinymediamanager.org/v3/b...etdown.txt
2019/09/19 23:30:28:542 INFORMATION No proxy appears to be needed.
2019/09/19 23:30:28:547 INFORMATION Downloading 0 resources [totalBytes=0, maxConcurrent=7]
2019/09/19 23:30:28:547 INFORMATION Dropping status 'm.resolving'.
2019/09/19 23:30:28:547 INFORMATION Dropping status 'm.downloading'.
2019/09/19 23:30:28:547 INFORMATION Launching without update!
2019/09/19 23:30:28:547 INFORMATION Dropping status 'm.launching'.
2019/09/19 23:30:28:549 INFORMATION Didn't find any custom environment variables, not setting any.
2019/09/19 23:30:28:550 INFORMATION Running C:\Program Files (x86)\Java\jre1.8.0_221\bin\javaw.exe
-classpath
D:\Tiny-Media\.\tmm.jar;D:\Tiny-Media\.\lib\FastInfoset.jar;D:\Tiny-Media\.\lib\activation.jar;D:\Tiny-Media\.\lib\animated-gif-lib.jar;D:\Tiny-Media\.\lib\api-scraper.jar;D:\Tiny-Media\.\lib\asm.jar;D:\Tiny-Media\.\lib\betterbeansbinding-core.jar;D:\Tiny-Media\.\lib\betterbeansbinding-el.jar;D:\Tiny-Media\.\lib\betterbeansbinding-swingbinding.jar;D:\Tiny-Media\.\lib\cling-core.jar;D:\Tiny-Media\.\lib\cling-support.jar;D:\Tiny-Media\.\lib\commons-compiler.jar;D:\Tiny-Media\.\lib\commons-io.jar;D:\Tiny-Media\.\lib\commons-lang3.jar;D:\Tiny-Media\.\lib\commons-logging.jar;D:\Tiny-Media\.\lib\commons-text.jar;D:\Tiny-Media\.\lib\converter-gson.jar;D:\Tiny-Media\.\lib\glazedlists.jar;D:\Tiny-Media\.\lib\gson.jar;D:\Tiny-Media\.\lib\h2-mvstore.jar;D:\Tiny-Media\.\lib\image-viewer.jar;D:\Tiny-Media\.\lib\imgscalr-lib.jar;D:\Tiny-Media\.\lib\isoparser.jar;D:\Tiny-Media\.\lib\istack-commons-runtime.jar;D:\Tiny-Media\.\lib\jackson-annotations.jar;D:\Tiny-Media\.\lib\jackson-core-asl.jar;D:\Tiny-Media\.\lib\jackson-core.jar;D:\Tiny-Media\.\lib\jackson-databind.jar;D:\Tiny-Media\.\lib\jackson-mapper-asl.jar;D:\Tiny-Media\.\lib\janino.jar;D:\Tiny-Media\.\lib\jaxb-api.jar;D:\Tiny-Media\.\lib\jaxb-core.jar;D:\Tiny-Media\.\lib\jaxb-impl.jar;D:\Tiny-Media\.\lib\jmte.jar;D:\Tiny-Media\.\lib\jna-platform.jar;D:\Tiny-Media\.\lib\jna.jar;D:\Tiny-Media\.\lib\joda-time.jar;D:\Tiny-Media\.\lib\jsoup.jar;D:\Tiny-Media\.\lib\jspf-core.jar;D:\Tiny-Media\.\lib\jsr173_api.jar;D:\Tiny-Media\.\lib\jsr305.jar;D:\Tiny-Media\.\lib\jtidy.jar;D:\Tiny-Media\.\lib\kodi-json-rpc.jar;D:\Tiny-Media\.\lib\logback-classic.jar;D:\Tiny-Media\.\lib\logback-core.jar;D:\Tiny-Media\.\lib\logging-interceptor.jar;D:\Tiny-Media\.\lib\loop-fs-api.jar;D:\Tiny-Media\.\lib\loop-fs-iso-impl.jar;D:\Tiny-Media\.\lib\loop-fs-spi.jar;D:\Tiny-Media\.\lib\miglayout-core.jar;D:\Tiny-Media\.\lib\miglayout-swing.jar;D:\Tiny-Media\.\lib\muxer.jar;D:\Tiny-Media\.\lib\nanohttpd.jar;D:\Tiny-Media\.\lib\okhttp-urlconnection.jar;D:\Tiny-Media\.\lib\okhttp.jar;D:\Tiny-Media\.\lib\okio.jar;D:\Tiny-Media\.\lib\retrofit.jar;D:\Tiny-Media\.\lib\seamless-http.jar;D:\Tiny-Media\.\lib\seamless-swing.jar;D:\Tiny-Media\.\lib\seamless-util.jar;D:\Tiny-Media\.\lib\seamless-xml.jar;D:\Tiny-Media\.\lib\slf4j-api.jar;D:\Tiny-Media\.\lib\threetenbp.jar;D:\Tiny-Media\.\lib\tinyMediaManager-LaF.jar;D:\Tiny-Media\.\lib\trakt-java.jar
-Dcom.threerings.getdown=true
-XX:+IgnoreUnrecognizedVMOptions
-XX:+UseG1GC
-XX:+UseStringDeduplication
-Xms64m
-Xmx512m
-Xss512k
-Dsun.java2d.d3d=false
-splash
-Djava.net.preferIPv4Stack=true
-Dfile.encoding=UTF-8
-XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches
-XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf
-Djna.nosys=true
org.tinymediamanager.TinyMediaManager
Is there a solution to the problem?
greeting
swen
-classpath
-XX:+UseG1GC
-Xms64m
-Xmx512m
-Xss512k
-splash
-Djna.nosys=true
greeting
swen
