Hello everyone.
I am new to Kodi, I've installed 18.1 x64 version, played around a bit, customized interface to my needs etc.
I have noticed that there's limit in length of folder names which is present in Confuence as well but it is better there (longer name and 3 dots at the end).
Here are screenshots so easier to understand what this is about.
is there any way to make this look like in Confuence? Currently it is cut directly through one letter.
(2019-09-21, 01:51)pkscout Wrote: [ -> ] (2019-09-20, 22:38)garson Wrote: [ -> ]Hello everyone.
It will require a modification of the skin. It's been on my list to track down to fix in my mod, but I haven't made time to do it. Unfortunately that means I can't tell you exactly which XML file you need to modify to fix this.
Thanks a lot.
Looking forward to fixing this "bug" or whatever. I am ok if it looks same as in Confuence skin but perfect would be, if possible, scrolling of names like file names are being scrolled already.
I see a lot of xml files, hard to track that for a newbie like me.
I'm not sure how I can use Artist Information Folder, nor that I actually need that.
Any update on this issue?
(2019-11-04, 15:44)garson Wrote: [ -> ]Any update on this issue?
Not from me. I think about doing it every time I see a truncated name and then get side tracked by life and don't get to it...
(2019-11-07, 04:20)garson Wrote: [ -> ]Thank you very much. I have adjusted it in includes.xml.
Is there a way to add three dots like in Confluence, if label is longer than what is set in width?
Based on changing
https://github.com/xbmc/xbmc/blob/master...s.xml#L853 to
<width>1000</width>
Then change
https://github.com/xbmc/xbmc/blob/master....xml#L1076 from
<width>auto</width> to
<width min="0" max="900">auto</width>
Also the clock might seem out of proportion now to the rest of the topbar. Clock section is found within same Topbar include at
https://github.com/xbmc/xbmc/blob/master...#L990-L997 so I've 2 suggestions here.
1. You can make the font size the same as the Breadcrumbs for folder name so change it from font_clock to font14
2. Alternatively you can keep similar font size proportion were the clock is larger but more in keeping. In font.xml I can see the original font45 for the Breadcrumbs has a 45pt size and that font_clock is 70pt so font_clock was roughly 1.5 times the font used for the Breadcrumbs. Using font14 which is 33pt size then 1.5 times that would be about 50pt, so you could change
https://github.com/xbmc/xbmc/blob/master...nt.xml#L77 from
<size>70</size> to
<size>50</size>
(2019-11-07, 12:18)jjd-uk Wrote: [ -> ] (2019-11-07, 04:20)garson Wrote: [ -> ]Thank you very much. I have adjusted it in includes.xml.
Based on changing https://github.com/xbmc/xbmc/blob/master...s.xml#L853 to <width>1000</width>
Then change https://github.com/xbmc/xbmc/blob/master....xml#L1076 from <width>auto</width> to <width min="0" max="900">auto</width>
Also the clock might seem out of proportion now to the rest of the topbar. Clock section is found within same Topbar include at https://github.com/xbmc/xbmc/blob/master...#L990-L997 so I've 2 suggestions here.
2. Alternatively you can keep similar font size proportion were the clock is larger but more in keeping. In font.xml I can see the original font45 for the Breadcrumbs has a 45pt size and that font_clock is 70pt so font_clock was roughly 1.5 times the font used for the Breadcrumbs. Using font14 which is 33pt size then 1.5 times that would be about 50pt, so you could change https://github.com/xbmc/xbmc/blob/master...nt.xml#L77 from <size>70</size> to <size>50</size>
This is awsome!
I have stretched folder names a bit, and clock still looks good to me.
Here's how it looks now.
(2019-11-05, 01:41)pkscout Wrote: [ -> ] (2019-11-04, 15:44)garson Wrote: [ -> ]Any update on this issue?
Maybe you can implement solution posted by jjd-uk in your mod?
Definitely a lot better with 3 dots then just cut off in the middle of some word.
(2019-11-07, 19:04)garson Wrote: [ -> ]This is awsome!
Looks like you extended the widths further than I suggested, did you remove the bit that governs display of the Now Playing file details which would also appear at the top as soon as you play anything? as if you haven't you'll get overlapped labels.
(2019-11-07, 19:06)garson Wrote: [ -> ] (2019-11-05, 01:41)pkscout Wrote: [ -> ] (2019-11-04, 15:44)garson Wrote: [ -> ]Any update on this issue?
Maybe you can implement solution posted by jjd-uk in your mod? Definitely a lot better with 3 dots then just cut off in the middle of some word.
I've got a working update here that uses the smaller font and includes the ellipses at the end. With the smaller font you're going to have to have a *really* long breadcrumb for the ellipses, so I couldn't test that, but all my other long stuff now fits with the smaller font. I have some other stuff I have to get done today, but I'll get the update into the repo later today or tomorrow.
(2019-11-07, 20:31)jjd-uk Wrote: [ -> ] (2019-11-07, 19:04)garson Wrote: [ -> ]This is awsome!
I forgot to add that I am using external players for audio and video, so Now playing shouldn't be issue for me. But thanks anyway, this can be helpful for other people, I guess.
