Full Version: How to adjust file locations in database?
I'm running Mariadb as a central kodi db for my home. I've recently found a need to change the folder name of my movies.
/snapraid/pool/videos
to
I have no idea how to work sql in the slightest. I know how to migrate a mythtv backend with the UPDATE command but I don't know how to list tables, or what they are called for Kodi.
Is there a simple way to do this? I have backups so a bit of trial and error won't kill me. I just don't even know where to start, or how to find the proper field to update.
*EDIT* A few minutes after this post the idea of backups occured to me. I dumped my databases to a non compressed file and just used sed. Then reloaded from that file. Working fine, took less than 2 minutes total. Posting solution. Use mysqldump to dump to file. Can find that info on Arch wiki.
sed -i 's/pool\/videos/pool\/video/g' $SQLDUMP
Followed by import to mariadb / mysql
cat $SQLDUMP | sudo mysql
I restarted the service just to be sure.
Thread moved to OS independent.
Replacing words in a text file can be done in any decent editor, although 'sed' can be pretty handy for those that know how to use it.
Doing a MySQL/MariaDB export is usually done with mysqldump
mysqldump MyVideos116 --add-drop-database > dumpfile.sql
Restoring is done via
mysql -u kodi -p MyVideos116 < dumpfile.sql
