Full Version: How could TMM show the missing episodes of a series?
Is this the option for it:
a) you must activate the option "display missing episodes" in the settings
b) you must have all data for missing episodes in your database.. the option from your screenshot is used to refetch that data if it is not available
Sorry, I do not understand. a) is set.
Quote:b) you must have all data for missing episodes in your database..
How can I get the data? And what do I have to do then?
a) you need to activate the option that tmm should display "missing" episodes in the tree (blue episodes)
this is done via settings -> Tv shows -> display missing episodes
b) tmm itself needs the data to display. since these episodes are _missing_ in your data source, tmm needs to fetch it somewhere from the net (same procedure as scraping available episodes).
If there are no blue episodes in your TV show, you have either all episodes or tmm does not have all needed data to display the missing ones.
The option from above is used to re-fetch this data from the net
Is this the tree(?):
What does blue episodes mean?
This is shown now:
I clicked the last item there, then TMM scrapes or so. And what do I have to do after, how can I show the missing episodes now? There definitely are missing episodes.
So to show the missing episodes TMM needs an Internet connection?
To "show" not; but we hopefully do not need to explain that scraping them online needs some internet....
Since "TMM scrapes or so", we might want to see the logfile what's going on.
You could upload it to some pastebin site...
the following is done with the same settings you have:
is there anything more to say?
