Due to a broken update of my QNAP NAS server which had removed my working Kodi 17 I'm now with a fresh new Kos Kodi 18.4 from QNAP club. Whereas my flac, DTS, AC3, SACD files are playing the mp3 streams from any radio channel I've configured via a local m3u list do not play anymore. The QNAP is connected via HDMI on an AVR with 7.1 channels and Kodi does detect this as well as allow passthrough in the expert audio system menu. Nevertheless no mp3 radio I see in the log file:
Quote:2019-09-21 21:36:43.499 T:140574237632256 WARNING: CPlayerCoreFactory::GetPlayer(VIERA VT30 Series): no such player: VIERA VT30 Series
2019-09-21 21:36:43.644 T:140576687126272 NOTICE: EPG thread started
2019-09-21 21:36:44.645 T:140574690608896 NOTICE: AddOnLog: PVR IPTV Simple Client: EPG file path is not configured. EPG not loaded.
2019-09-21 21:36:48.519 T:140575420446464 WARNING: CPlayerCoreFactory::GetPlayer(Denon AVR-X7200W): no such player: Denon AVR-X7200W
2019-09-21 21:37:01.504 T:140576542717696 WARNING: CAEUtil::GuessChLayout - This method should really never be used, please fix the code that called this
2019-09-21 21:37:01.505 T:140576542717696 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://cristina.torontocast.com:8007/mp3-320
2019-09-21 21:37:01.505 T:140576542717696 WARNING: PAPlayer::QueueNextFileEx - Failed to create the decoder
Is there any way to *attach* the kodi.log now with debugging ...
https://paste.kodi.tv/ is somehow unhandy for large log files
No, as we have no desire to bloat the forum database with such files (hence the request to use pastebin sites).
Paste.ubuntu.com can usually accept larger log files, so try that.
But the log files normally shouldn't be so large, if you follow the normal procedure (below) of enabling logging, rebooting then reproducing the issue and uploading that straight away.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
As a test, make a text file containing just the URL, name it torontocast.strm (without any .txt extension) and point Kodi at that. Does that play?
I just tried it here under Windows (Kodi 18.4) and it played fine. Can you replicate that?
By the way - Kodi should be able to play M3U files directly (open them in the files view mode under the music menu entry, or the videos --> files one). See
strm (wiki) for more details.
(2019-09-22, 10:30)DarrenHill Wrote: [ -> ]As a test, make a text file containing just the URL, name it torontocast.strm (without any .txt extension) and point Kodi at that. Does that play?
By the way - Kodi should be able to play M3U files directly (open them in the files view mode under the music menu entry, or the videos --> files one). See strm (wiki) for more details.
the .strm method works perfect ...
Quote:2019-09-22 11:00:42.168 T:140020836612224 NOTICE: VideoPlayer::OpenFile: /share/Multimedia/Music/test.strm
2019-09-22 11:00:42.724 T:140018072938240 NOTICE: Creating InputStream
2019-09-22 11:00:44.002 T:140018072938240 NOTICE: Creating Demuxer
2019-09-22 11:00:48.897 T:140018072938240 NOTICE: Opening stream: 0 source: 256
2019-09-22 11:00:48.897 T:140018072938240 NOTICE: Finding audio codec for: 86017
2019-09-22 11:00:48.897 T:140018072938240 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp3float
2019-09-22 11:00:48.899 T:140018072938240 NOTICE: Creating audio thread
2019-09-22 11:00:48.899 T:140018697606912 NOTICE: running thread: CVideoPlayerAudio:rocess()
2019-09-22 11:00:48.901 T:140018697606912 NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
Maybe the autodetection for the radio channels does fails with PCR:
Quote:2019-09-22 09:05:53.147 T:140019919501056 DEBUG: CCurlFile::Open - File <http://cristina.torontocast.com:8007/mp3-320> is a shoutcast stream. Re-opening
the entry in my m3u list looks like this:
To be honest that's the method I would use anyway for this kind of thing rather than IPTV simple. And at least there's a workaround if you do need to use it for some reason.
But I'll raise it on the PVR dev channels and see if there's someone with more deep knowledge who can give inputs here.
(2019-09-22, 11:10)DarrenHill Wrote: [ -> ]To be honest that's the method I would use anyway for this kind of thing rather than IPTV simple. And at least there's a workaround if you do need to use it for some reason.
Hmmm ... AFAICR from
https://en.wikipedia.org/wiki/SHOUTcast those are used to transport mp3 or aac ... that in theory it should work or do I have to port parts of playercorefactory.xml to advancedsettings.xml ??
I have tested this user the M3U entry you provided and it works for me.
(2019-09-22, 11:38)phunkyfish Wrote: [ -> ]I have tested this user the M3U entry you provided and it works for me.
That is somehow strange ... what goes wrong with this KODI 18.4?
2019-09-22 09:05:53.149 T:140019919501056 DEBUG: File::Open - redirecting implementation for http://cristina.torontocast.com:8007/mp3-320
2019-09-22 09:05:53.149 T:140019919501056 DEBUG: CurlFile:arseAndCorrectUrl() adding custom header option 'Icy-MetaData: 1'
2019-09-22 09:05:53.149 T:140019919501056 DEBUG: CurlFile::Open(0x7f58dc073da8) http://cristina.torontocast.com:8007/mp3-320
2019-09-22 09:05:53.473 T:140018030974720 DEBUG: Thread ShoutcastFile start, auto delete: false
2019-09-22 09:05:53.474 T:140018039367424 DEBUG: Thread FileCache start, auto delete: false
2019-09-22 09:05:53.474 T:140018039367424 DEBUG: Thread FileCache 140018039367424 terminating
2019-09-22 09:05:53.475 T:140018030974720 DEBUG: Thread ShoutcastFile 140018030974720 terminating
2019-09-22 09:05:53.475 T:140019919501056 WARNING: CAEUtil::GuessChLayout - This method should really never be used, please fix the code that called this
2019-09-22 09:05:53.475 T:140019919501056 ERROR: CAudioDecoder: Unable to Init Codec while loading file http://cristina.torontocast.com:8007/mp3-32
