Full Version: Trakt completely stopped working
The Trakt add-on no longer works in all video plugins that support Trakt, under accounts it just shows Trakt as a title and there's no field to enter a user ID.  I've already uninstalled and reinstalled the add-on and even re-downloaded it from Kodi.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Where am I supposed to locate this log file?
Found the log file and uploaded it here enonuzoqef.kodi (paste)
The Trakt.tv list Manager no longer works on any computers I have it installed on, stopped working a few days ago.
